Author Topic: Ambient Temp PID on DashHawk reading -40  (Read 855 times)
  • Lifetime Supporting
« on: August 26, 2014, 02:49:59 PM »
Usually a -40 display reading means intermittent connection so I'm guess its the sensor
Just started displaying -40 today for the Ambient air temp.  The Intake Air Temp PID is working and I'm not throwing any codes.  The MAF has the Intake air temp sensor in it but changed the MAF out with a Spare one I have with the same result.
Anyone know where the sensor is located on an 07 Solstice GXP?
THANKS
« Last Edit: August 26, 2014, 03:59:20 PM by tazz »
Re: Ambient Temp PID on DashHawk reading -40
« Reply #1 on: August 26, 2014, 06:27:52 PM »
I believe it's on the front of the radiator housing under the airbox
« Reply #2 on: August 26, 2014, 07:01:25 PM »
So Ill need to take off the plastic air dam thing that directs the air to the AC condenser and radiator?
« Reply #3 on: August 26, 2014, 10:52:47 PM »
Damned if i can find it.
« Reply #4 on: August 27, 2014, 04:27:34 PM »
As far as I can tell, the Solstice doesn't have an ambient sensor - rather, it's derived from intake temps by the ECM.
This is where it is on the Sky (part #4) - perhaps you can check on your car?
From: http://parts.nalleygmc.com/showAssembly.aspx?ukey_product=2789631&ukey_assembly=390092&ukey_make=1031&ukey_model=14670&ukey_driveline=0&ukey_trimlevel=15564&modelYear=2009
« Reply #5 on: August 27, 2014, 04:45:11 PM »
If its derrived its freaking accurate as hell.  My truck has a temp sensor and it reads the same as my trucks temp sensor.
Thanks TS
« Reply #6 on: August 27, 2014, 06:25:53 PM »
Works today. :-)
Its gotta be a sensor or its coincidence because on Monday i pulled the shround open to access the top of the AC and radiator coils and sprayed water to clean both out.  The next day the issue manifested itself and now its gone .  The only engine bay items that got wet were the AC Condensor and Radiator.
