Author Topic: New WERKSracing TCM tuning service for the GM T68 TCM!!!  (Read 4082 times)
« on: October 09, 2014, 07:05:41 PM »
We are also proud to release our new TCM tuning service for the GM T68 TCM!!!  :yay:
 The WERKSracing Automatic 2.0T LNF T68 TCM Tune is custom programmed to your specs for a completely new driving experience!!!
 Features - Increased line pressure for firmer shifts
 Raised shift point rpms
 Raised shift point mph
 Decreased shift time for faster shifts
 Removal of torque management within TCM
 Available for
 HHR SS Auto Trans
 Solstice Auto Trans
 Sky Auto Trans
 Daewoo G2X Auto Trans
 $200.00 Includes standard ground return shipping!
 When placing order a re-flash information sheet will be sent to you via e-mail or fax (for fax please include your fax number in the comments section). Please fill out completely and send along with your ECM to -
 Performance Autowerks, Inc. 12425 Rhea Dr. Suite A Plainfield, IL 60585
Check it out and order here - WERKSracing TCM tuning service for the GM T68 TCM
Re: New WERKSracing TCM tuning service for the GM T68 TCM!!!
« Reply #1 on: October 13, 2014, 11:37:56 AM »
WERKS would it be possible to get auto OEM times vs auto Tuning times.  For example OEM 0-60/0-100 vs 0-60/0-100 Tuning times.
« Reply #2 on: October 13, 2014, 12:09:15 PM »
We will probably be posting quarter mile results from a drag strip first.
Offline Jim
« Reply #3 on: October 14, 2014, 11:08:07 AM »
I've tuned my auto trans with the 2.25 beta release with great results. Not only does the trans shift quicker at WOT than it did on the factory tune but it shifts smoother around town than my 7 series BMW. My wife drives the car as much as I do and she can't believe how well it shifts around town. The cruise shifts are almost unnoticable.
IIRC, factory shift times were close to .5 seconds at WOT and I've reduced my times down to .125 seconds at 236 lb.ft and up and everything below 236 to .20 seconds.
If you're getting an engine tuned for an auto setup, the only way to effectively raise your redline is to tune the trans as well because the stock trans tune in the TCM will shift at the lower stock rpms regardless of what you've set the ECM to.
I run the WR3 turbo in my setup so I can't compare mine to the stock setup plus my elevation here is 3700 feet so I'm probably not as fast as some of the other WR3 setups but I'm more than happy with it as it sets. 4.4 second 60-100 (4.2 sea level) times and 8.1 second 40-115 (7.7 sea level) times are good enough for me. (For now anyways). I'm running a somewhat conservative tune on E28 right now (27psi @ 20* up top) and know that there's much more to be had from moving to E47 but it's nice to be able to enjoy the car for a while without messing with the tune which I've been doing for a few months now.
Come spring time I will probably make the move to E47 and bring those times down even more.
« Reply #4 on: October 14, 2014, 11:54:59 AM »
Good job Jim, thanks for the info, great stuff!
Of the 3 automatic cars I have done here now locally they are certainly a night and day difference versus the stock program.
Offline Jim
« Reply #5 on: October 14, 2014, 12:13:19 PM »
Thanks Dave! It really is a night and day difference.
« Reply #6 on: October 15, 2014, 09:19:15 PM »
Yeah the car is TOTALLY DIFFERENT.:-):-)
