Author Topic: New - DDMworks K04 Block off plate  (Read 894 times)
« on: December 11, 2014, 12:26:50 PM »
This is a little must have when installing an aftermarket blow off valve on the Solstice/Sky with the stock turbo.
The stock K04 turbo uses and internal bypass valve, and if you decide to use and external higher flow unit like the Synapse we install, you have to block off the passage on the turbo to make sure boost does not leak back into the intake. We created the perfect drop in replacement made from CNC 6061 aluminum and then hard anodized black to function and look great for the life of your car. Our unique design does not require you to re-use any of the factory parts to the bypass valve, instead our design is a single solid piece of aluminum with a rubber seal that positively will not allow any air to get past it. The new turbo bypass block off plate comes with new bolts and full instructions needed to complete the job. If you want to personalize your setup a little, powdercoat options are available.
Simple little piece, easy to install and if you are going with an aftermarket blow off valve on the stock turbo, this is a must have. Only $30.
DDMWorks K04 Turbo Block Off Plate
Offline cbr6
Re: New - DDMworks K04 Block off plate
« Reply #1 on: December 12, 2014, 04:01:11 PM »
what is the benefit of using a blow off valve vs. the stock bypass ?
  • Lifetime Supporting
« Reply #2 on: December 12, 2014, 04:31:41 PM »
How much boost you can run would be my guess.
« Reply #3 on: December 12, 2014, 04:39:00 PM »
A couple reasons, some folks like to vent to atmosphere and also the synapse we use can dump more air quicker than the stock bypass valve.
Offline Graywolf
« Reply #4 on: December 15, 2014, 12:01:00 PM »
It works great, Thats how I run mine.  25ls of boost
