Author Topic: Another Notice from Pontiac (automatic transmission models)  (Read 650 times)
  • Lifetime Supporting
« on: December 25, 2014, 01:18:07 PM »
Yesterday in the mail I received a letter from GM that's states...
As the owner of a 2007 model year Pontiac Solstice equipped with an automatic transmission, your satisfaction with our product is very important to us.
This letter is intended to make you aware that your vehicle's transmission shifter may not properly transmit an electrical signal that allows the ignition key to be turned counter clockwise past the accessory mode to the "LOCK" position after the vehicle has been shifted into park.  If this occurs, the ignition key cannot be removed from the ignition cylinder without depressing the manual release plunger located on the underside of the steering column as described in the owners manual.  A key left in the accessory position for an extended period of time may result in severe battery drain and a possible no start condition.
Do not take your vehicle to your General Motors dealer as a result of this letter unless you believe that your vehicle has the condition as described above.
What We Have Done:  General Motors is providing owners with additional protection for the condition described above.  If this condition occurs on your 2007 Pontiac Solstice within 15 years of the date your vehicle was originally placed in service, regardless of vehicle mileage or ownership, the condition will be repaired for you at No charge.  Diagnosis or repair for conditions other than the condition described above is not covered under this special coverage program.
What You Should Do:  If you believe that your vehiclehas the condition described above, repairs and adjustments qualifying under this special coverage must be performed by a General Motors dealer.  You may want to contact your General Motors dealer to find out how long they need to have your vehicle so that you may schedule the appointment at a time that is convenient for you.  This will also allow your dealer to order parts if they are not already in stock.  Keep this letter with your other important glove box literature for future reference.
Reimbursement:  If you have paid for repairs for the condition described in this letter, please complete the enclosed reimbursement form and present it to your dealer with all required documents.  Working with your dealer will expedite your request, however, if this is not convenient, you may mail the completed reimbursement form and all required documents to Reimbursement Department, PO Box 33170, Detroit, MI 48232-5170.  The completed form and required documents must be presented to your dealer or received by the Reimbursement Department by December 31, 2015, unless state law specifies a longer reimbursement period.
« Last Edit: December 29, 2014, 10:47:34 AM by DeepBlueGXP, Reason: Editied subject for transmission »
    • Ryuk
Re: Another Notice from Pontiac
« Reply #1 on: December 25, 2014, 02:24:09 PM »
Nice to see it is at least covered.
Offline sirwm
« Reply #2 on: December 29, 2014, 08:24:57 AM »
yes - I got the same letter for my 09.
wr
