Author Topic: My 500HP Engine Build  (Read 15813 times)
Offline IBDRINKEN
  • Lifetime Supporting
  • Donkey Master
« on: January 13, 2015, 06:21:06 PM »
So I'm in the process of having my engine built by the one and only Dave @ DDM. My goal is between 500-600 to the ground and I will drive this everyday. I would be happy with around 525hp. I will be going with the 5th injector Kit to help with the fuel issues the LNF has. I see some some people go with the different cam with the vp better fuel lobe and springs as well. Is there any benefit it is it just a preference. I also bought a new waters pump as well. I have just about all of the parts and awaiting pricing on a few things such as the sleeves, clutch and have to figure out which turbo I will be going with.
« Last Edit: January 13, 2015, 06:28:13 PM by IBDRINKEN »
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
Re: My 500HP Engine Build
« Reply #1 on: January 13, 2015, 07:41:47 PM »
Pretty much same parts as mine until now, waiting to see the "heavy" ones like sleeves, turbo, clutch, etc :D
PS: Wiseco 86.5mm were not in stock in the beginning of the year so I got a delay of a couple of weeks :(
Offline IBDRINKEN
  • Donkey Master
« Reply #2 on: January 13, 2015, 07:49:30 PM »
That sucks you have to wait. Mine are collecting dust on DDM'S shelf lol. I'm just waiting on prices for the sleeves and the clutch, then have to figure out the turbo
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #3 on: January 13, 2015, 08:11:26 PM »
So you saying you have Kelu's parts sitting on DDM's shelf
« Reply #4 on: January 13, 2015, 08:57:11 PM »
I was going to say that first picture of all the bolts should look pretty familiar to Kelu.
« Reply #5 on: January 14, 2015, 12:25:35 PM »
:lol:  :lol:  :lol: he wouldn't be so careless with my parts, especially if we would have met  :D
They even look familiar to you  :lol:
« Reply #6 on: January 14, 2015, 02:08:15 PM »
I seem to remember two bags of bolts that looked exactly like that.
« Reply #7 on: January 14, 2015, 05:36:43 PM »
That is easy the EFR 7163 or the EFR 7670
« Reply #8 on: January 14, 2015, 06:57:19 PM »
Around here the Precision turbos are very well appreciated, just another idea
Offline IBDRINKEN
  • Donkey Master
« Reply #9 on: January 14, 2015, 07:47:32 PM »
Someone on the big board posted the power graph on my other thread
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
    • Ryuk
« Reply #10 on: January 14, 2015, 07:59:35 PM »
So both of those graphs show less than 500 HP.
How do you plan to hit your 500-600hp goal with that turbo?
Are you going to Add Meth or run E85?
Offline IBDRINKEN
  • Donkey Master
« Reply #11 on: January 14, 2015, 08:09:08 PM »
I plan on running meth and haven't decided on the turbo yet. I was just posting the info and if I read it correctly the 7670 puts out between 400-650hp
« Last Edit: January 14, 2015, 08:19:00 PM by IBDRINKEN »
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
    • Ryuk
« Reply #12 on: January 14, 2015, 08:32:55 PM »
Don't worry about breaking 500HP
Get a good performing turbo and build a 400+ engine that drives awesome on the street.
« Reply #13 on: January 14, 2015, 09:42:33 PM »
Let me run the dyno- I'll guarantee 500 hp on the stock turbo shows up on a dyno graph. Someone has already done it!
May the Schwartz be wit you
« Reply #14 on: January 14, 2015, 10:15:09 PM »
Someone let you run a dyno?
Offline Wartie
« Reply #15 on: January 15, 2015, 07:51:42 AM »
GJ had the Dyno facing down hill.  :devil:
Offline JesseB
« Reply #16 on: January 15, 2015, 10:10:27 AM »
wait, how did the 7163 spool faster?
« Reply #17 on: January 15, 2015, 12:03:50 PM »
That makes sense, the store selling Preparation H was probably at the bottom of that hill.
Offline Wartie
« Reply #18 on: January 15, 2015, 03:07:55 PM »
Oh the things we never will forget.
    • Ryuk
« Reply #19 on: January 15, 2015, 05:28:42 PM »
It did give me a great signature
« Reply #20 on: January 15, 2015, 08:22:41 PM »
And then there's Wartie's avatar.
Face it, most people remember a good joke when they hear one.
« Reply #21 on: January 16, 2015, 10:14:40 AM »
I see STI in the title of the dynos, could be a 2.5l engine which could produce different outputs than our engines ;)
I think it would be better to read the compressor maps of the turbos and to see similar engines installs.
Same as my opinion ;)
PS: Don't let GJ do anything on your car ...
Offline IBDRINKEN
  • Donkey Master
« Reply #22 on: January 16, 2015, 12:23:30 PM »
Well the goal is to get to 500 then I can always detune it.
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
Offline IBDRINKEN
  • Donkey Master
« Reply #23 on: January 16, 2015, 06:38:56 PM »
Just purchased a set of ferra oversized 1mm valves. I figured since the motor is apart and the hp that I'm wanting I might as well replace or upgrade everything. I would rather be safe than sorry. I'm now looking at werks spring and trying to decide between stage 1 and stage 2 cams
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
Offline IBDRINKEN
  • Donkey Master
« Reply #24 on: January 17, 2015, 08:55:32 PM »
What does anyone know about the Opel injectors. Any I sight on these would be much appreciated.
http://shop.zzperformance.com/store/p/1239-Opel-HP-Direct-Injection-Fuel-Injectors.aspx
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
