Author Topic: 2 codes keep popping up help p0558 and p0367  (Read 1146 times)
Offline phillyphan08
« on: April 23, 2015, 02:56:51 AM »
i changed both sensors cam and brake booster pressure (2nd map)
all the wiring looks fine, battery has 12.6 volts and hasnt had any issues starting any suggestions? and i changed the crank sensor and looked at the wiring coming into the ecu.
P0558 - Brake Booster Pressure Sensor Circuit High Voltage
P0367 - Camshaft Position Sensor 'B' Circuit Low Bank 1
thanks
mike
Offline scanner
Re: 2 codes keep popping up help p0558 and p0367
« Reply #1 on: April 25, 2015, 08:00:44 PM »
Have DVOM & Scantool?  These are needed to do a good investigation. DVOM is needed to test voltages and resistances, 10M Ohm input impedance minimum.  Scantool lets you see what the ECM "sees".
Clear Skies!
Scanner
« Reply #2 on: April 26, 2015, 02:49:52 PM »
i have a colt meter and my scan tool isnt too good
