Author Topic: No Start P0615 Need advice  (Read 14025 times)
Re: No Start P0615 Need advice
« Reply #25 on: May 24, 2015, 09:33:53 AM »
So you had Microsoft install the tune on your car and all it needed was a reboot?
Glad to hear it's all squared away
Offline KappaScar
« Reply #26 on: May 24, 2015, 10:40:20 AM »
That's determination. I'm glad the problem is solved. Any guess why electrical connectors were corroded?
The ECM pins were due to a broken rubber seal and it sets just below the washer fluid. I suspect someone spilled fluid on the connector. As for the other connectors, I am thinking the high resistance created in the ECM connector caused higher current, due to the lower voltage, since voltage and current are inversely proportional. Kind of a domino effect.
Offline KappaScar
« Reply #27 on: May 24, 2015, 10:42:41 AM »
Yeah that was quite the challenge. Glad you got to the bottom of it!
Thanks!
Offline KappaScar
« Reply #28 on: May 24, 2015, 10:45:20 AM »
 :coffee:
