Author Topic: rear differential  (Read 2723 times)
Offline Erick
Offline ryansalazan
Re: rear differential
« Reply #1 on: October 17, 2016, 09:47:33 PM »
its a bit tricky honestly but not impossible. I had 2 other people helping me. Its pretty much a chore to get the axles out. But once you get those out everything it basically just follow the instructions
Offline Erick
« Reply #2 on: October 18, 2016, 01:15:23 PM »
thanks,  has anyone done a video?
Offline Wartie
« Reply #3 on: October 19, 2016, 12:19:58 PM »
There is a Gj joke there somewhere.
« Reply #4 on: October 19, 2016, 01:14:27 PM »
That would probably be a dirty video.
Offline Gil
« Reply #5 on: November 26, 2016, 05:44:54 PM »
Hi from newby Gil
Does anyone know if I can put 1.42 gears from a  CTS in my 07 Sol? It's a NA 2.4 with LS Dif. I would love to drop my cruising RPM from 2100 with the 1.9 gear ratio down to 1600 rpm at 60 mph.
Thanks
« Reply #6 on: November 26, 2016, 07:25:17 PM »
Hi from newby Gil
Thanks
Hmmm. Not sure.
Wouldn't you be way low on power if you did that?
« Reply #7 on: November 27, 2016, 01:41:21 PM »
That's what I was thinking.  It would probably take longer to get to 60 and use more gas to maintain that speed.
Offline JRinKY
« Reply #8 on: December 01, 2016, 11:30:37 AM »
For a manual transmission, the only real negative change is to acceleration from a standing start. Once you are moving you will be in a different gear than you are used to, but performance won't really be any different. Doing this with an auto could cause shifting issues, but then again it may not.
