Author Topic: Fast Wheels FC04A 19x9.5 +45  (Read 429 times)
  • Lifetime Supporting
« on: March 21, 2017, 01:39:38 PM »
I posted this in another forum, wanting to get it over here onto kappaperformance.  I went through all this trouble so I can run inexpensive 19x9.5 wheels that are pretty much off-the-shelf.  I made a $1,000 gamble on this, it was almost a disaster but I figured it out in the end.
Diameter: 19"
Width: 9.5"
Offset: +45mm
Tire Size: 275/35R19 Ventus V12
Concentric spacer required, hub is 65.1mm
Long story short, these wheels require a modification.  You be the judge as to how difficult it is depending on your resources and knowledge. Technically, I was able to get the front wheels fit, but mostly likely because the Big Brake rotor is slightly thicker (also, the hub cap wouldn't snap so I machined them anyway).
FCO4A in Titanium:
Final result:
Front Stick Out:
Rear Stick Out:
Trial Fit:
Machine ~5mm off non-structural part of hub see image, this is the part that hits the wheel:
This shows both the shiney machined surface, and the 2nd downside of the CV axle stick out.  I painted the CV axle threads and nut with some flat black paint and blends well:
These wheels on the dyno!
