Author Topic: Back, sorta...  (Read 2743 times)
  • Lifetime Supporting
Re: Back, sorta...
« Reply #50 on: July 14, 2017, 11:27:18 PM »
I don't own a GM anymore.  I am confident I would still win.
You will be on your 20th water pump and 5th timing chain
For an LS3? The timing chain is about a foot long, and only connects the cam to the crank...as it should be. ;) The water pump is still a weak spot on these motors, but usually fails closer to 200k miles than the 60k my Kappa's did.
FWIW, my I feel that if you can live with the initial cost/high gas mileage, the GM V8's are fantastic engines. The amount of aftermarket support is incredible, I can pick and choose vendors. Honestly, for some things AC Delco is a great choice...others, I've got MSD, Hollet, Edelbrock, and many other to choose from. The aftermarket support for my truck, to speak nothing of the Camaro, puts the Kappa to shame.
But I buy used, I'm not paying money for a warranty/stealership hassles but have to deal with any problems that crop up. The truck has only had minor issues since I ditched my Kappa for it almost six years ago. The only issues have been a dead stereo, u-joint, dead battery, (normal for a truck that age) and the fan blower resistor. Hopefully the Camaro follows suit. With the main GM V8/transmission combos you can be pretty much sure your power train won't have any issues. Other bells and whistles? Not so much so, but so long as I can still drive I'm fine with that.
The other advantage of buying used is you can kinda tell if a vehicle is having weird issues or not in it's service history.
(FWIW, I buy most of my AC Delco parts from Amazon, since my local stealership seems intent on charging triple what Amazon does. The local Dodge dealership? Oh they price match Amazon...)
All LS motors for this family...
2005 Chevy Silverado Z71 Crew Cab
2012 Chevy Camaro 2SS RS M6
    • Ryuk
Re: Back, sorta...
« Reply #51 on: July 15, 2017, 08:48:18 AM »
If you have a local Napa, they tend to kick ass.  If they don't have it at your local store, they will deliver it to your local store within 1 day in most cases and their staff tends to be way more knowledgable about cars than Pep Boys or Autozone.
Re: Back, sorta...
« Reply #52 on: July 17, 2017, 06:38:25 AM »
Why am I visualizing Speedy Gonzales with his little legs spinning in circles now?
Hahhaha, I was thinking to something similar, tazmanian devil (cartoon version too) running like crazy :D
Yes, though that place is under new ownership, and I don't feel like they're putting the time/money/energy into the Friday night street car events that the prior owner did.
I asked because imho MIR was one of the best places to set up record times. Speedracer from this forum did that with Kappa and then new camaro :D pity he is not a forum guy. I also went there with him once and I was impressed by the quality of prep ;)
Re: Back, sorta...
« Reply #53 on: July 17, 2017, 07:50:46 AM »
He still holds the stock 5th-gen ZL1 record as far as I know.
The prep seems to ebb and flow with whatever special event is running that Friday night/weekend. One night this year they had a bunch of grudge cars running, along with some cars for the big event the following Saturday. There was also a Drag Week Tri-Five running in the mid 7's. Track prep that day was incredible, that's when I managed the 13.3. Tires were so sticky that the car shaked for about a mile and a half after I left the track, the rocks and debris was glued on that strongly.
They've also greatly reduced the number of Friday night street car events. Right now the next one is at the end of August, and the final one for the year is in September.
Re: Back, sorta...
« Reply #54 on: July 24, 2017, 11:39:48 AM »
Well I'm dumb.
I've been shifting at 6000-6100 RPM, as the factory tach shows redline at 6200 RPM.
After playing with HP Tuners on a run where I purposefully bounced it off the rev limiter, I learned something interesting...redline is 6600 RPM. Some googling confirms this. Why I never thought to check this I don't know, but in my defense the tach does have red starting at 6200 RPM...
500ish RPM that I'm not using has to have had an affect on my times...
Re: Back, sorta...
« Reply #55 on: July 24, 2017, 01:08:48 PM »
So long as the torque curve shows it's usable RPM otherwise you might be better off shifting sooner.  Something more to look into.
Re: Back, sorta...
« Reply #56 on: July 24, 2017, 02:41:07 PM »
Not sure what tune you have (if any) but most of the tunes (Trifecta and certainly GMPP) raise the redline from the stock 6200, anyway.
Re: Back, sorta...
« Reply #57 on: July 24, 2017, 03:54:50 PM »
I will be the one to tell TS that this time he is _wrong_?  :D
Got him  :devil:
« Last Edit: July 25, 2017, 01:48:04 PM by Kelu »
Re: Back, sorta...
« Reply #58 on: July 24, 2017, 04:52:35 PM »
The way these 5th gens are geared, you lose a ton of mechanical advantage each time you shift. Usually I cross the beams at the top of third, so between first and second that's a very useful 1000 rpm I haven't even been touching.
And to be clear, I sold my Kappa back in 2011, and since then have only bought vehicles with the number of cylinders that SHOULD have been in the Kappa.
Re: Back, sorta...
« Reply #59 on: July 24, 2017, 09:04:28 PM »
I will be the one to tell TO that this time he is _wrong_?  :D
Got him  :devil:
Who is this TO?
Re: Back, sorta...
« Reply #60 on: July 25, 2017, 01:48:51 PM »
Who is this TO?
I meant TS, corrected, mister right :P
Re: Back, sorta...
« Reply #61 on: July 25, 2017, 04:36:11 PM »
Why?  You think the tunes don't raise the redline?  I know for sure that GMPP does.
Re: Back, sorta...
« Reply #62 on: July 26, 2017, 12:05:17 AM »
TS-
Please reread a few of the posts before Kelu really starts to make fun of you.
May the Schwartz be wit you
Re: Back, sorta...
« Reply #63 on: July 26, 2017, 05:13:32 AM »
TS-
What's wrong with you???? Do you realize that you trying to stop some fun on the forum??? Geez...
Oh I think I know the reason of your weird behavior: you need TS' scope :lol:
Re: Back, sorta...
« Reply #64 on: July 26, 2017, 11:25:02 AM »
I like TS. I don't like most of the rest of you.
Re: Back, sorta...
« Reply #65 on: July 26, 2017, 01:13:31 PM »
Invite TS and his O-scope out to SD tell him you need to settle a bet  :poke:
    • Ryuk
Re: Back, sorta...
« Reply #66 on: July 26, 2017, 08:37:48 PM »
Exactly
No use revving to 8000 if the power drops off way before that.
T.S.  Wrong GM car.
 :lol: :lol:
Re: Back, sorta...
« Reply #67 on: July 27, 2017, 11:33:02 AM »
Doh!
Re: Back, sorta...
« Reply #68 on: July 28, 2017, 02:05:58 AM »
    • Ryuk
Re: Back, sorta...
« Reply #69 on: July 28, 2017, 07:06:25 PM »
    • Ryuk
Re: Back, sorta...
« Reply #70 on: August 26, 2017, 11:42:10 AM »
I found this while surfing the web in my Alfa Glass house
https://blackflag.jalopnik.com/corvette-z06-owners-hit-gm-with-class-action-lawsuit-be-1796070293
Looks like only need 16 minutes to humiliate a car with 3 times the HP.
 :lol: :lol:  :lol:  :lol:
