With the car warmed up, I was able to use HP Tuners to relearn the crankshaft sensor (aka CASE learn) which got rid of the P0315 Crankshaft Position Variation Not Learned. Then a new code popped up, P0016. Following the diagnostic procedure, I pulled the VVT actuator and manually jumpered it to check if it was actuating, which it was. Next it says to check the timing....as if the intake cam skipped a tooth.
After figuring out it is nearly impossible to line up the colored timing chain links, I came up with a plan. First I put the crank at TDC, using a rod inside Cylinder 1 and then making sure the I can see the timing marks on the cam gears. I attempted to try and reference the manual that said put the intake mark at approximately 2 o'clock position, which is about 30 degrees. Well it not that easy or accurate:
I then got the idea to count the chain links between the exhaust mark and the intake mark. I found a youtube ecotec timing tutorial and was able to pause it to see the colored chain links, then count the links between the marks. I also confirmed with this service manual diagrams showing the whole front view with all links and timing marks. I also counted the links on an old timing chain. The magic number is 16, this includes the link at the mark on both cam gears.
Count the links between the marks challenge:
I counted 16.5. The intake camshaft skipped a tooth at some point, I'm guess during the first time cranking it over with the starter...unless you have some ideas.
I fixed it quite easily, I pulled the tensioner completely and then using a large adjustable hammer and a 24 mm wrench on each camshaft hex, I pulled the intake cam gear towards the exhaust gear and then helped that new slack in the chain between them jump the teeth on the intake side, I got it back to 16 links between them. Before starting the engine, I installed a brand new tensioner...as the one I used was pulled from the 2015 LEA with 20k miles. Maybe I didn't reset it correctly idk, didn't take a chance.
After a 110 mile commute on Wednesday, everything is looking great!!
Next I need to finish and fix the suspension. The free Eibachs I got are too low (I just have the fronts installed lolol). My driveway is so low and I am not a big fan of slamming my cars (just my personal opinion, they're cool as long as I don't own it). I am going to install spring seat spacers. I did some measuring and some maths to sketch the suspension, then calculated at the shock I need a 0.375" spacer to move the wheel 0.500".
I made a prototype last night:
Stock
Lift Kit
