Author Topic: Twincharged Solstice = Turbocharger + Supercharger  (Read 41384 times)
Offline MattM
« Reply #525 on: February 24, 2021, 08:48:56 AM »
Having come up utilizing megasquirt I personally prefer speed density over MAF.  Could just be the fact that that's what I used for so long.
One other thing I would recommend you look into is the J&S safeguard.  It monitors and will cut advance on a per cylinder basis instead of just monitoring and cutting spark across the whole engine.  Back when I had it a growing number of drag racing and (I think) NASCAR teams were using it.
Offline MattM
« Reply #526 on: February 24, 2021, 09:10:16 AM »
Oh got a caveat..it looks like NASCAR has now banned the J&S safeguard from use.
On the speed density tuning with megasquirt I felt MUCH more comfortable tuning 1 VE and 1 advance table and that was with two modes more the engine since the supercharger had an electric clutch one mode was forced induction and one was n/a.  I dont know if your new ecu has just the two table but Id assume probably not (cuz you seem to like complicated things. Jk!).
Back on the J&S safeguard I am so surprised that folks that personally tune through hp tuners dont swear by it, but you never hear about it here.
For you though, with as much power as you are running and the fact that speed density is not directly measuring airflow (it still works well though) I really think if you took the time to read up on the J&S safeguard and used one you would DEFINITELY thank me after.  It makes tuning WAY easier too!
« Reply #527 on: February 25, 2021, 01:01:18 PM »
Good to hear on the MAP tuning, 300 kpa max on the VE table sounds like a good time  :D
Offline MattM
« Reply #528 on: February 26, 2021, 08:55:42 AM »
Does your new ecu just use one VE table and one Spark Table?
I still definitely recommend a J&S safeguard for tuning.  It will make tuning so much easier and quicker for you!
« Reply #529 on: March 03, 2021, 12:14:53 PM »
Looks like it just has basic knock retardation for all cylinders.  With this ecumaster, Page 62 shows that it can trim fuel dose per cylinder when using individual cylinder EGTs.
https://www.ecumaster.com/wp/wp-content/uploads/2016/11/emu_manual.pdf
Offline MattM
« Reply #530 on: March 03, 2021, 03:03:41 PM »
No, you should read into it a little more the jands safeguard retards timing nad monitors knock on an INDIVIDUAL cylinder basis.  There will always be one or two cylinders that need less advance than the others the jands allows for the individual cylinder advance monitoring and knock prevention.
With what you are saying, your ecu will only add and take out fuel per cylinder not change the advance (kind of a big distinction).
I'm not telling you to replace your new ecu with the jands I'm telling you that adding the jands will allow you to run a much better tune more quickly and actively monitor eahc cylinder for detonation.
Offline MattM
« Reply #531 on: March 03, 2021, 11:38:10 PM »
Sorry I was posting from my phone...I think that came off harsh even though I wasn't intending to..
So before I told you about my v6 ford probe gt that I dynoed at 245whp and 220ft lbs of torque at 8psi from an older generation clutched Eaton m62.  All I had was a homemade meth injection kit for cooling.  Without meth the IATs would routinely get to around 200 degrees and with meth around 100 degrees.  That meth kit was not optimized for a v6 and undoubtedly was getting more meth to some cylinders than others yet the car was tuned aggressively on a stock engine with 120k miles and 10k was boosted.  It never blew!
So one of your questions was how I got 245whp on 8psi with a supercharger that was clearly out of its efficiency range.  The answer was the jands safeguard.  It monitored each cylinder separately and would only cut advance for the cylinder that pinged which allowed me to run an incredibly aggressive tune and not blow the engine!  If you look at all of my racing vids on YouTube for supercharged probs gt you'll see tons at the track and a bunch of highway races all on the same stock engine, he'll I trapped a few times at 108 and a few at 106 at the track in that car with no weight reduction.  Problem is I could never figure out how to launch it.  My best time was a 13.8 with like a 2.1 60ft....God I wish I still had that car!!!
Anyway that was all done bc of the jands.
« Reply #532 on: March 08, 2021, 10:24:03 AM »
I went to the website and checked it out when you brought it up.  I totally understand the theory with that unit and it is a great idea in theory.  I don't see it as a solution at this point, being my engines are wearing out and stock ECU is in over it's head (or I am with the ECU).  I don't think J&S is a solution however, it's seems like more of a really good band-aid.  As you mentioned, this device would be a perfect counter-measure for uneven distribution of high volume fogger type methanol injection.  I am going down the path of E85 and uneven distribution is a much lower risk, so not sure how bang for the buck beneficial the J&S would be yet.  Let's say the car is fully optimized and setup, then sometimes it will pull 4 degrees timing due to knock events, and that 4 degrees timing could be worth 30 hp for sure!  But at what cost?  $800 for the hardware, $1500 for dyno days, and 40 hours of setup, chasing electrical noise, sensor locations, swapping sensors, murphy's law.  For a cheap ass diy builder it is not appealing at all, for someone who wants to be competitive and win on race day, it seems like the greatest thing invented.
Offline MattM
« Reply #533 on: March 11, 2021, 08:57:26 AM »
I get what you are saying, but it took me literally 3 hours to  swap the knock sensor, wire it between the megasquirt and distributor and mount it.  You can also hook it into the stock GM knock sensor if you don't want to use the Bosch sensor.  It would cost you around $650 total if you use your stock GM sensor.
You initially set the sensitivity by tapping the block lightly with a hammer (to have it pick up).  Then I loaded a VERY conservative spark table and the jands has a headphones jack that you plug the headphones in and can listen to what the jands is hearing.  It then took me about an hour driving the car in multiple condition (full throttle boost, partial throttle boost etc) listening in and you adjust the jands sensitivity based on what you are hearing and it's set.  You don't need a $1500 for dyno (although with your new ecu you will prolly wanna dyno tune it anyway) or 40 hours of setup.  Also if there were electrical noise and you wanted to confirm simply using the headphones, but, that said, my car was a rats nest of wires and I never ran into electrical noise.
That said, it's your car and you don't want to use it I just wanted to make sure you had all the facts with it.
I'll be interested in seeing what your new ecu does for you!
« Reply #534 on: March 12, 2021, 05:19:19 PM »
The ecumaster has built in knock protection, so for now I'm glad I at least have that.  A friend of mine got the Tunernerd Pro kit and says it works pretty good, he got his old procharger mustang dialed in (he flashes the stock ECU like old times still), the benefit of Tunernerd is the analysis software and graphing display.
Offline MattM
« Reply #535 on: March 15, 2021, 08:51:50 AM »
Sounds good!  Cant wait to see the beast tear up the tracks!
« Reply #536 on: April 06, 2021, 02:23:39 PM »
You long await, so I give long update. Good news is I have a lot more time to work on the car, bad news is I am unemployed.  I was part of the decimation process along with many others while the company struggles with a dried up market for automotive testing and engineering services, being outside of the home base in Austria it is inevitable I suppose with this political circus directly impacting me personally in too many ways these days, I can only take so much. Short-term, I'd like to get the car finished for many reasons such as I already have 99% of the parts and tools, the car is broke and it should be fixed, maybe it can help me get a job [if it works haha], dead mustangs, burnouts and 12 sec 1/4 mile slips.
For a little bit I have had a secret engine build going on in the background, it's using hahn forged pistons and I re-sleeved a LE5 block saved it from the dead.  I need to acquire rods and rod bearings to build up a short block and then I will treat it better than my own and sell it to someone out there looking for an affordable sick built bottom end to help the engine builder pay their mortgage  :idk:
Looking at the Supurbo twincharger engine, I am backyard blueprinting this LEA 2 (the block with the leaking bed plate) because tri-metal rod bearings starting to show copper under the babbit and go through all the oiling system and go through the oil pump to rule out or correct any oil issues.  Also, the head is "wore out" check out the exhaust valves, all of them leaking substantially.  Looks like a common issue especially with running so rich and oil past the rings doesn't help keep those valve seats cleaned up. Also the exhaust valve seats were a bit black all around and seemed like carbon built up on the seat areas.
After soda blasting this same head, exhaust seats hand lapped well after this:
There are some radial circular marks in both cyl 4 intake valve seats, I am going to a buddies shop Thursday to look at it and try and clean it up.  I'd guess that may be dirt/debris entered cyl 4, all the other intake seats look good.
I pulled valves out of a LEA head, the intake valves were disgusting caked in carbon good ol' direct injected.  I chucked them in a drill and used a gasket scraper and just like a scraper on a wood lathe I literally turned carbon off the valves.  Some of them I could form a continuous "chip" of carbon holding it in one spot as it dug down.  The gasket scraper is much softer than the stainless valve, proof is the 8 valves I did not being gentle.  Followed up with a 3M nylon bristle disc, then a bit of green scotch bright and now they look great.  The issue with these is, they are 9-14% heavier than the LE5 valves.  Odd thing is, the Solstice LE5 intake valves are about 42g, the Junkyard LE5 valves are about 44g, and the LEA valves are a heavy duty 48g that you can visually see and why I started checking mass.  I don't know what RPM this would matter with my ZZP cams and springs, but an interesting observation.
I have the bores touched up in LEA 2 with the ball hone again and checked the pistons to the bores again, looks like there is 0.0042" to 0.0046" bearing clearances, recommended is 0.0040".  Moving forward looks like I'm working on getting the head squared away and build up the bottom end, the car should be running in short time.  I'll probably fire it up with the stock ECU to get the initial break in ring seating started and double check the VVT stuff (position signal, park position, range) and hopefully dive into the standalone ECU.
Offline MattM
« Reply #537 on: April 06, 2021, 07:05:53 PM »
Damn dude!  That really sucked man!  I really feel for you man!  I would say though..as talented as you are if you don't get hired back to your old job after the economy fully recovers you'll definitely find a job just as good if not better than the old one!
Keep up the good work on the car man!  Enough people will start to notice and it will speak for your talent man!
« Reply #538 on: April 07, 2021, 04:35:30 PM »
Cleaned up the chambers, 80 grit and 120 grit taper rolls, and then scotch bright rolls.  It softened up a lot of edges/corners, and had to work a bit to get rid of small "holes" everywhere in the chamber casting surface of the chambers, so probably expect 3 rolls each of 80 grit and 120 grit for each chamber, you go through them fast because of the tighter shrouded areas around the valves so you lean on the tip to do most of the work.  After I get the valves seats and valves squared away the chambers/valves will all get 120 grit blasted followed by a fresh coat of cerakote V-136.
Looks like I can start on the bottom end build up.  Here is the backyard hot tank, mixture of purple power and dawn, and turned up the water heater temperature this morning and ran a hose from the basement faucet to get the hot water.  20 minutes that's all, purple power not recommended for aluminum but for any lingering dirt and grease, it will do the trick and worth the slight staining of machine aluminum surfaces.  Of course, power wash it 5 times from each angle then power wash it some more after this soak.
