Hi all, recently my 09 Pontiac Solstice has been acting up. The turn signal would not disengage or sometimes have trouble engaging, but I already have the replacement part coming in the next several days.
Now, whenever I turn off the car and open the door, the door chime beeps a lot faster than the usual key still in ignition chimes. After shutting the door and locking the car, the rear and front lights remain on forever. This killed my battery a couple times. I tried pulling every fuse and cable harness to figure out which system is triggering this. Only the BCM fuse in the engine bay, or the BCM harness in the passenger footwell will stop the chiming. Any thoughts on this? Does the car still think its supposed to be running even though it is turned off and locked? Thanks!
