Author Topic: 09 Solstice in Missouri  (Read 1066 times)
Offline gashwill
« on: March 05, 2019, 09:20:43 PM »
Hi,
On January 26, 2019 my wife and I bought a 2009 Solstice with 7,284 miles on the odometer. We are looking forward to Spring so we can enjoy the car. It's only been out of the garage a couple of times since we got it because of the crummy winter weather.
Re: 09 Solstice in Missouri
« Reply #1 on: March 06, 2019, 12:42:59 AM »
Welcome to the forum.  There are a lot of us waiting for some warm weather to go out and play.
« Reply #2 on: March 06, 2019, 05:48:47 AM »
Welcome to the forum. Yeah sure can't wait for spring!
« Reply #3 on: March 06, 2019, 09:47:49 AM »
Hi,
Welcome!
What are your maintenance plans?  With that low of mileage after 10 years, I would highly recommend completely swapping all your fluids so that you basically reset the car back to being nearly a new car (that comes with all new fluids).  Engine oil, coolant, brake fluid, trans fluid, differential fluid.  Also consider your fuel may be expired, hopefully the tank is low and you can dilute it with fresh gas and maybe some techron fuel system cleaner.
« Reply #4 on: March 06, 2019, 10:16:29 AM »
« Reply #5 on: March 06, 2019, 05:12:36 PM »
