Author Topic: Boost Juice and Devilsown Brew is not 49% methanol  (Read 2514 times)
« on: January 20, 2020, 06:32:30 PM »
Re: Boost Juice and Devilsown Brew is not 49% methanol
« Reply #1 on: January 20, 2020, 07:13:23 PM »
Thought I read somewhere that someone else found Devilsown frozen in the winter.
EDIT: It was you a few years ago that posted this. Others on the web have reported the same thing. The take away would have to be that you're better to make your own I would think.
http://www.kappaperformance.com/forum/index.php?topic=11614.0
« Last Edit: January 20, 2020, 07:17:19 PM by Sly Bob »
« Reply #2 on: January 21, 2020, 12:39:25 AM »
I used it for many years in both my sols and never has an issue
« Reply #3 on: January 21, 2020, 06:29:30 AM »
But you ARE in Florida...   :D
« Reply #4 on: January 21, 2020, 07:48:33 AM »
Water injection (H2O alone) is effective; so you may want to experiment with blue washer fluid and save 80%.
« Reply #5 on: January 21, 2020, 07:49:46 AM »
Has it been that long?!  Consider this, there is a direct correlation between my employment status and activity on my youtube channel (I produce lots of videos when I don't have a job).  I'm trying to do both this year let's see what happens.
« Reply #6 on: January 21, 2020, 10:55:51 AM »
So, living in Florida (the Sunshine State), how many times did you come out in the morning to find it frozen?  :poke:  :devil:
« Last Edit: January 21, 2020, 12:45:05 PM by TomatoSoup »
« Reply #7 on: January 21, 2020, 12:41:38 PM »
I was going to look up some factual information to troll, but then see that Florida is the 51st coldest state (next to Hawaii) judged by the coldest ever recorded temperature.
« Reply #8 on: January 21, 2020, 06:52:49 PM »
. . . and how many states are there?
:curious:
« Reply #9 on: January 21, 2020, 08:37:32 PM »
50 but Illinois counts twice because the Chicago machine always ends up with more votes than possible.
« Reply #10 on: January 22, 2020, 11:07:37 AM »
:curious:
lolol,  :banghead: wish I had a time machine.  Dang wiki list threw me off is my excuse https://en.wikipedia.org/wiki/U.S._state_and_territory_temperature_extremes
