Author Topic: Turbo Help  (Read 255 times)
Offline Reblacklaf
Turbo Help
« on: September 29, 2022, 07:50:56 PM »
Well, the dealer worked on my 2008 GXP and dinged the return oil line on the turbo and on the drive home SMOKE. They think the turbo is bad. Thing is it is a modified PAW big wheel which is not available. Dealer says they will pay for replacement. Can someone recommend a unit that will fit along with all plumbing that would be needed to fit. I am also running a Solo exhaust system with the 3" cat and the dealer really doesn't want to do (or have the setup) to do a custom install.
Thanks the site has been a big help in the past.
Randall Black
Re: Turbo Help
« Reply #1 on: September 29, 2022, 08:38:41 PM »
Have you called the guys at performance autowerks and asked them?
Offline Reblacklaf
Re: Turbo Help
« Reply #2 on: September 29, 2022, 10:08:42 PM »
Yes, I've been in contact with Dave.
Re: Turbo Help
« Reply #3 on: September 29, 2022, 10:23:13 PM »
What are the specs of the turbo? Maybe post and see if anyone has one?
Offline Reblacklaf
Re: Turbo Help
« Reply #4 on: September 29, 2022, 11:26:45 PM »
It's the stock turbo that was reworked by Dave to put the Big Wheel in it. This was done in 2010 I believe. I've had the car since new.
Randy
Re: Turbo Help
« Reply #5 on: September 30, 2022, 04:50:19 PM »
I guess the question then becomes what's damaged on the turbo and can it be repaired or could it be combined with a new stock turbo to build up a replacement.
    • Ryuk
Re: Turbo Help
« Reply #6 on: September 30, 2022, 06:54:25 PM »
You can always go back to a stock turbo and retune appropriately.
Offline Reblacklaf
Re: Turbo Help
« Reply #7 on: October 01, 2022, 09:48:01 AM »
Thanks everyone. I have been talking with Grant at Turbokits and believe we have come up with a solution. I will let you know if it works.
Randy
