KappaPerformance is the only forum withZERO ADS. We need support to continue this, consider premium.KP does not send emails or sell your info. Please email KappaPerformance@gmail.com for account help.
They can be repairedI have a pictures in the Punisher thread where I bought several tulip panels for the parts. I flipped one over and have pictures of the hinges and all the parts. In fact, in one of the posts I used a heat gun to activate the adhesive for the flap hinge structure - which is glued to the bottom of the tulip panel - and removed it. It is possible to swap out the entire hinge assembly if yours is damaged badly.We now have a 3d printer who will print hinge pins and the actuation arm in nylon that work very well. Chickenwire has printed the other side small metal clip with the D hole in it. We also found an online source for hinge springs and some hinge parts.The cables should still be available. If you cant find the info let me know and I will look up the part number for you.I have three tulip panels I used for parts in the parts bin if you need a mount. The parts are identical for Sky and Solstice even though the tulip panels are not interchangable.If you need flaps, there is a guy on FB and active on the Sol forum that is selling pretty good replacements for something like $100 each. They are fiberglass and come painted and the one I bought as a test is 95% good. Good enough for most peopleIf you want more info, let me know. I am on Sol forum several times a day.a fews pointershttps://www.solsticeforum.com/threads/punisher.65168/page-129#post-1884097https://www.solsticeforum.com/threads/punisher.65168/page-130#post-1887817https://www.solsticeforum.com/threads/punisher.65168/page-136#post-1972985
Both cables were broke on my Solstice. Went to hardware store and purchased 4 foot of stainless steel cable and attched electrical ring terminals to ends. Works as good as original for $4.00. Eliminated the plastic clips at top. It is a much cleaner fit than stock.
