Author Topic: H&R lowering springs  (Read 1994 times)
« on: July 31, 2009, 04:46:40 AM »
regarding the H&R set 40/50mm (1.6/2 inches) lowering springs , i wanted to lower the center of gravity of the car (also add ponts to the looks of it  :drool: )
so i went for these springs with the standard Bilstein sport shocks
what i ve felt driving is that the springs handle much better the weight of the car at turns (difficult to explain that in english-swift of the weight may be the expression).
also from the apex and on with throttle, the car slightly drifts its way out of the corner, which is very nice feeling. it sure makes the handle much better.
here are 2 pics from before and after (not from the same angle but the difference is noticeable)
stock
http://img356.imageshack.us/img356/4415/p1020088.jpg
H&R
http://img24.imageshack.us/img24/5435/img2923ywu.jpg
Offline Rogue
Re: H&R lowering springs
« Reply #1 on: July 31, 2009, 07:27:33 AM »
Nice to hear that this has worked out well for you. The visual improvement is notable - quite nice! Have you had any trouble with ground clearance?
Go N.A.K.3.D..
« Reply #2 on: July 31, 2009, 07:43:29 AM »
no trouble with ground clearance so far, but i m always carefull on this one. after all, greek roads are not the best quality... as you imply, one has to be more carefull of this issue after lowering. but the handling and looks really pay you back (at least paid ME back)!
