Author Topic: Leaky trunk - again!  (Read 2062 times)
Offline Demothen
« on: October 28, 2009, 03:41:02 PM »
So today I discovered the source of the slight funk in my solstice that I've had for the last couple of days.  The carpet around the inflator and back wall of my trunk is fairly wet.  I already had this problem once but that water was pooled on the passenger side of the trunk. And was apparently due to the rubber boot leaking where the wires pass from the decklid into the rear bumper.  This was fixed by the dealer with some adhesive to seal around that boot (weatherstrip glue presumably).  That fix still looks good, so I really don't know how the water got into the trunk this time (obviously the insane amount of rain lately had something to do with it). Anyone suggest another way the water could have gotten from the drain area into the trunk floor?  I usually park with the front of the car level or higher than the back, though its possinble I parked nose-down in the rain at least once recently.
Thanks!
  • Lifetime Supporting
Re: Leaky trunk - again!
« Reply #1 on: October 28, 2009, 04:11:40 PM »
Opening the trunk with it nose down even slightly will put a ton of water on the carpet.  Please don't ask how I know :)
Lambo Doors
« Reply #2 on: October 28, 2009, 04:28:55 PM »
How do you know Critter? You knew I had to ask.
« Reply #3 on: October 28, 2009, 04:29:44 PM »
The two drainage boots can become dis-lodged in the trunk causing the water that drained to go into the trunk.
« Reply #4 on: October 28, 2009, 04:34:32 PM »
Saturday at the airport goat
Lambo Doors
Offline Demothen
« Reply #5 on: October 28, 2009, 04:58:06 PM »
Drainage boots eh? Ill look into those for sure.  I think there was a bit of water the last time I was in the trunk, and it was facing downhill slightly.  Hopefully that's all it is.  I just hope the soggy case of soda in the trunk didn't leave a nice logo on my carpet!
Offline Va_Sky
« Reply #6 on: October 28, 2009, 09:47:54 PM »
I had the same problem in the same area with my Sky. Turned out to be a gap in the sealant used to seal the body and the fiberglass trunk where the trunk and the body meet. I found it by pulling the carpet back and pouring water into the tray above the tail light and watched where it ran into the trunk. Upon inspection of the area I found a gap in the sealant the factory uses. I then took some clear RTV and a putty knife and filled in the gap in the seal. Hope this helps.
08 Redline Midnight Blue
Black/Black,
Three Pedals (Do They Make'm Any Other Way?),
Spoiler, Chrome, Monsoon,
Opel GT Antenna, V2 Windrestrictor,
JPM Embroidered Visor Covers and Console,
GM Stage 2
DDM - Backbone, Pro-Beam, Fuel Filter, Powder Coated Valve Cover,
Coil Cover, Charge Pipes, Intercooler, Big Wheel Turbo
High Country Solstice Sky Club
Offline Demothen
« Reply #7 on: March 29, 2010, 02:18:00 PM »
Still have not been able to solve this problem...I have tried to reseal the trunk seams in the drainage area, to no avail.  The problem seems to be getting worse.   I am wondering if water is making it over the trunks weatherstrip near the passenger sidee tail light, this is where the water seems to collect most on the carpet, and my trunk sits higher on that side.does anyone know what i s involved in adjusting trunk fitment? Or any other suggestions?  I have tried dumping a bucket of water into the drain area, but not been able to locate the source of the leak.
Thanks
Offline WWI Flying Ace
« Reply #8 on: April 30, 2014, 03:38:22 PM »
Was this ever resolved?  Nothing like bringing a thread back from the past.
It has been raining cats and dogs for days.  I got in my car this morning and the driver's seatbelt was wet...not sure where the leak is.  Looked at the trunk seal and it looks good, and the top seems to be ok, but there is no denying the diagonal wet mark on my jacket.  The carpet inside the car is dry...it is the coiled seat belt (and likely whatever is around it where it lives) that is wet.
Any suggestions on where the culprit might be?
I never wonder to see men wicked, but I often wonder to see them not ashamed.
-Jonathan Swift
« Reply #9 on: April 30, 2014, 03:45:16 PM »
Not to shed light on the leak, but you should check UNDER your carpet to see if it's wet and needs drying out.  There is a LOT of padding under the carpet, that can act like a sponge - even though the carpet top can feel dry.
« Reply #10 on: May 02, 2014, 03:02:05 AM »
^^^^^^. This
May the Schwartz be wit you
« Reply #11 on: May 02, 2014, 03:17:49 PM »
Thanks...did that and it ain't.  The rain here was torrential...we had leaks in our Commander too, and it has never leaked before.  I'm going to chalk it up to the fact that there were gallons and gallons of water falling out of the sky in a short period of time.  We actually got kicked out of the restaurant we were in on Wednesday because the river it was nearby started to rise and was coming in the dining room.
-Jonathan Swift
« Reply #12 on: May 02, 2014, 08:09:30 PM »
Mine is under a cover, guess I should pull the cover off and check inside.  We did get some rain this week.
Lambo Doors
Offline syclone0182
« Reply #13 on: May 02, 2014, 08:33:30 PM »
Don't feel bad...our passenger floorboard is soaked from where we have a leak somewhere.
« Reply #14 on: May 03, 2014, 02:57:44 PM »
My driver's side was leaking, it would actually drip water on my foot when going through a deep puddle. I took it into Saturn Service as it was still under warranty and the found it immediately. They hadn't sealed it right at the factory.
