Forum > Racing
Front brakes swap
<< < (9/10) > >>
Kuprito:
Are you calling spindle to the knuckle?
I put front kunckles on rear because of the front brake brackets... How could you fit front brakes on rear an look stock?
Carbon Sky:
Well to me this is a spindle:
http://www.newdaymotorsports.com/images/newspindle.jpg
Anyways, interesting . . . I had no idea the front "knuckle" was interchangeable with the rear.
--- Quote from: Kuprito on December 07, 2009, 07:18:45 PM ---Are you calling spindle to the knuckle?
--- End quote ---
snaponbob:
Since there is a bunch of hair splitting going on, the technical term is (usually) "suspension upright". The actual hub on our suspensions is the wheel bearing assembly. On the front end, the spindle is attached to the hub (bearing). Parsing that further, wheel spindles can be bolted or welded to the upright. HTH SOME.
Kuprito:
The word in spanish is: Mangueta
It comes from MANO that means HAND
It's very similar than english because knuckle has to see with hand...
Carbon Sky:
I'm just still a little surprised that the uprights on the front and rear are interchangeable in terms of mating with the rest of the suspension.
Navigation
Message Index
Next page
Previous page
Go to full version
