Author Topic: Single Gauge A Pillar Pod and Aeroforce Gauge  (Read 1889 times)
Offline SOLE-STUCE
« on: April 30, 2010, 01:46:24 PM »
Do you offer a Single Gauge A Pillar Pod to mount your Aeroforce Gauge?
I saw the dual Pillar but I am not sure what to run as a second gauge since the Aeroforce gauge covers it all....
Offline KWhale
  • Playing with my
Re: Single Gauge A Pillar Pod and Aeroforce Gauge
« Reply #1 on: April 30, 2010, 09:06:10 PM »
You didn't ask me S-S, but that never stops me from yakking!!
 I have the dual pod and really like it. The Aeroforce gauges display 2 things at 1 time, so with 2 gauges, you can see 4 things all the time.  It's a pain in the butt to have to keep scrolling through the numerous options by pushing the little buttons on the gauge edges.  Go with the dual ones if you can afford to waste the mod money, it's worth it :)
Offline SOLE-STUCE
« Reply #2 on: May 01, 2010, 09:23:04 AM »
Thank you for the idea.....I can go for 2... :yay:
Will they both will plug into the same ODBII port or do you need some kind of pig tail??
Offline LiquidPT
  • TechHead
    • LiquidPT's website
« Reply #3 on: May 01, 2010, 12:57:49 PM »
You need to buy them as a pair (master/slave setup). See aeroforcetech's website
LiquidPT aka Matt
driving Black Sun
Offline badbird
« Reply #4 on: May 01, 2010, 07:54:11 PM »
Our good friends at DDM can get you the gauges...and pillar pod, thats where I got mine!!
San's Chicklets
Debadged
Custom Fender Vents
Painted Calipers
DDM Works Backbrace
GMR Tune (thanks Martin)
Offline Spedee
    • Spedee
« Reply #5 on: May 02, 2010, 07:45:53 AM »
There is also the steering column pod mount.
I put my Aeroforce in it that I bought from Dave at DDM so that the shift lights are in my view.
