Author Topic: Differential Cooler Discussion  (Read 22215 times)
« on: October 09, 2010, 07:29:16 PM »
The Solstice Performance book has information about this. Pretty sure it's a simple install.
Offline spartan
Re: Differential Cooler Discussion
« Reply #1 on: October 09, 2010, 07:55:00 PM »
Thanks for starting a new thread Kenny.  To repeat, I asked DDM about doing a differential cooler and offered to pick up the CTS-V bolt-on kit (as shown in the Solstice Performance pub).  The kit runs about $1K but I hoped to pick it up somewhere for less, perhaps even used.  I figured Dave could take a look at it and rig something up for less than half that with a very sturdy attaching structure to boot.  Dave was somewhat amused at the idea but felt the market would be pretty small, and said he would want to play with it to make sure a diff cooler would even would work well on the Kappa.  I think if enough of us showed interest he might consider giving it a go.
I have to say the CTS-V diff cooler kit did not look all that different from the oil cooler kits I've seen on e-bay that looked very substantial, for approx $200.  Then again, I really don't know what I'm talking about.  Thoughts from those who do?
« Reply #2 on: October 09, 2010, 07:58:53 PM »
Transmission noob speaking: Needs more info.
« Reply #3 on: October 09, 2010, 08:06:06 PM »
I'd be shocked to find out that any decently tough metal fan wouldn't fit the bill, $1k seems a bit extreme. (Overcharging just because it's for a Caddy? I don't doubt it.)
« Reply #4 on: October 09, 2010, 08:42:27 PM »
Here's a description of what the diff cooler is and what it looks like.
On a T2-legal Solstice, the rear differential will need a cooler system to control the temperature of the differential fluid during racing. This system includes an electric pump, heat exchanger, braided steel lines and electric fan
From: http://www.highperformancepontiac.com/tech/hppp_0712_pontiac_solstice_scca_racer_build/photo_11.html
« Reply #5 on: October 09, 2010, 08:52:13 PM »
So this is for racing mainly?
« Reply #6 on: October 09, 2010, 09:01:14 PM »
Yes. Only for extended racing.
Offline Kuprito
« Reply #7 on: October 09, 2010, 09:58:00 PM »
What is the difference in performance between a cooled dif. and non-cooled?
Solo + Magnaflow 3" exhaust
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Custom Backbone (1/2")
« Reply #8 on: October 09, 2010, 10:23:26 PM »
I don't think it's intended for performance so much as reliability.
Offline spartan
« Reply #9 on: October 09, 2010, 10:25:38 PM »
Precisely what Dave of DDM wanted to quantify were he to consider going forward with such an offering.  How effective would such a cooler be?  If performance warranted he could feel good about putting the kit forward to the kappa community.  Testing might include a number of runs without the cooler and then with the cooler in order to justify, similar to the performance data he posted on the backbone and more recently on the tower brace.
« Reply #10 on: October 10, 2010, 12:18:39 AM »
I think wether it's justifiable or not will have much to do with the final price...$1k no way, could buy a better diff for that price...but for a couple hundred bucks it would be a nice "Just in case" for those who really thrash their cars.
I don't see any need whatsoever for street use or even autocrossing, this is only something that a road racer might consider. Since the performance book thought it was a good idea, if I was putting my Kappa on a road course you can bet I'd be trying to install something similar.
« Reply #11 on: October 10, 2010, 11:05:11 AM »
Would a "better" diff necessarily mean you wouldn't need the cooler on a road course?
FYI I think only limited slip diffs would need one of these.
Offline Graywolf
« Reply #12 on: October 10, 2010, 08:16:14 PM »
Its a waste of money unless your driving on road racing courses. Try putting 10 laps on a 2 mile course and everything is hot hot hot. Engine will overheat 1st - You need a race radiator,brakes,then diff Its all about reliability with no performance improvement, just keeping your car intact.
Offline Imaj
« Reply #13 on: October 10, 2010, 08:37:42 PM »
Humm...I am running a 3.1 mile track in a couple of weeks...7 - 20min sessions. I think I will be fine. What have you encountered Graywolf?
« Reply #14 on: October 10, 2010, 08:59:39 PM »
The CTS-V doesn't need it and it has exhaust piping on each side.  :)
« Reply #15 on: October 10, 2010, 09:07:29 PM »
Why wouldn't the CTS-V need it?
« Reply #16 on: October 10, 2010, 09:11:27 PM »
For SCCA the CTS-V uses one but we don't for HPDE we don't, even with an extra heat source emitting next too it.
Offline Graywolf
« Reply #17 on: October 11, 2010, 08:50:21 AM »
I am not aware of any problems yet . There is no way to know if this is causing a problem or damage until it breaks. Since GM racing thinks you need one ,we probably should install one for track cars.
« Reply #18 on: October 11, 2010, 09:03:28 AM »
It's like getting a flu shoot
Preventive medicine.
« Reply #19 on: October 11, 2010, 12:20:13 PM »
I get my preventive care covered 100% by my new health insurance plan. I'll call them to see if diff coolers are covered ;)
« Reply #20 on: October 11, 2010, 12:20:32 PM »
That just means you guys aren't going fast enough at HPDE events ;)
« Reply #21 on: October 11, 2010, 01:43:01 PM »
Why not get a temp probe back there on the Diff and see what it's fluid is running at first?
« Reply #22 on: October 11, 2010, 02:13:26 PM »
SA,
why use an expensive temp probe, just stick your finger in there.
« Reply #23 on: October 11, 2010, 03:21:43 PM »
Does the race Solstice use the stock 3.91 diff? Surely not the 3.73 for the race car. :)
Offline Graywolf
« Reply #24 on: October 17, 2010, 09:37:24 PM »
Parts needed for diff cooler- Source Gm Solstice Performance-Heat exchange/fan[B&M Hi Tech FC],-6 hose 5 feet, wiring and switch, fittings -6 90 degree full swivel [5], -6 to 1/2 inch NPT straight[2],-6 to M18x1.5 straight[1],-6 to -6 straight[2],custom low profile diff case plugs, Weldon 9200KA pump. Custom fabricate a mounting bracket. It is mounted where your muffler use to fit.
