I wanted to get some protection for stuff inside the car when parked with the roof open(or at least some warning of/to would-be thieves
). So, I bought an Install Essentials (AKA: DEI, Cobra, Viper, Python) 508D Radar Field Disturbance Sensor. That was the
easy part.
Next, I had to work out how to trigger the car alarm when it detects motion. I figgered that I could just tie the, active low, alarm wire to the passenger door switch line, to emulate someone opening a door - so far so good. The more difficult part was tying in to the car's electrics to have the 508D sensor be armed at the right times - this led to the following simple system circuit...
NOTE: I take no responsibility if you fry your BCM or any other electronics, etc. by following the info in this post. Do so at your own risk!
[attachment=1]
This uses a latching relay (Relay1) to 'detect' the state of the door locks, supplying switched-ground to the sensor when the doors are locked. Unfortunately, the doors also lock when you're driving along - and I didn't want to get irradiated, or have the lights turn on and the 'door open' alert going off every few seconds. So I had to include a regular relay (Relay2) to ensure that the sensor is only armed when the accessory power is OFF. Some other notes:
- R1 and D1 are to 'snuff' back-EMF from the relays turning on/off.
- I had to add D2 when I found that the sensor could be grounded, and turned ON, through it's alarm wire via the actual door switch when the door was opened (hmmm!).
- The On/Off override switch is optional - I added it "just in case".
- Also the piezo alarm/siren is optional, but recommended. The sensor has a two stage detection - I tied the first stage to the siren to chirp if someone gets close, and the second stage to only trigger the car alarm if someone reaches inside. Both of these 'levels' are adjustable in the 508D (read the manual:
508D.PDF).
Installing the 508D is easy. It fits nicely under the center-console armrest - I melted a couple of holes in the carpet under there and just used zip-ties to cinch it down. Fed the cable forward and to the right of the shifter, straight to the BCM in the passenger footwell area.
Making this addition requires a certain amount of soldering skill and electrical knowledge/understanding. So I'm not going to do a full "How-To" writeup here (if you need that, I wouldn't suggest you attempt this). However I'll try to help if you have any questions, plus I'll give a parts list of what I used and add some photos of my install, to help the knowledgable along
FYI - total parts cost, incl the sensor, was around $50.
First the Parts list...
- Install Essentials 508D Radar Field Disturbance Sensor (AKA: DEI, Cobra, Viper, Python) - got mine from Amazon, but available all over under the different manufacturer names.
Components I got from Digikey (again, you can substitute equivalents and get them from other vendors):
- 12V Relay (Tyco D3026 - Digikey part# PB1118-ND)
- Latching 12V Relay (Tyco D3046 - Digikey part# PB1117-ND)
- 2.7K OHM 1/4W Resistor (Digikey part# CF14JT2K70CT-ND)
- 1N4001 Diode (x2, Digikey part# 641-1310-1-ND)
Parts I had (or forgot to get from Digikey) from Radio Shack:
- PC Board (RS part# 276-150)
- Piezo Siren (RS part# 273-079)
Misc parts I had:
- On/off switch
- Case (for relays)
- Wire, Wire-sleeve, Connectors
PHOTOS... This was my relay box showing the circuit board & components. As you can see, I used a PC power molex connector for the relay 'inputs'. The orange wire is the switched ground 'output' going off to the on/off switch and sensor. WARNING: I had assumed the relay coil for Relay 2 was non-polarised, like regular relays. I found out, when it didn't work, that it IS polarised and had to do a couple of wiring mods - hence the second short blue wire:
[attachment=2]
Here's the relay box installed (velcro) in the footwell:
[attachment=5]
The 508D sensor, nestled comfortably under the center console armrest:
[attachment=3]
[attachment=4]
That's it. Works like a charm. Good luck if you want to do this!
