Author Topic: GM's Direct-Injected Engine Future  (Read 1475 times)
« on: January 20, 2009, 09:38:54 AM »
"GM's  Engine Future" by Nate Martinez
"Quote"  (Motor Trend)
"With so much on the line and even more to prove to consumers, General Motors has previewed its latest in fuel-saving technologies for the upcoming 2009 and 2010 model years.  As is the case with other manufacturers, GM has chosen to go the most cost effective direct injection (DI) route to up EPA estimated mpg fuel ratings, decrease emission outputs and maintain sufficient power in its future vehicle lineups.  The highlight of GM's DI surge will be a pair of engines -- a 2.4L four-cylinder and 3.0L V6 -- set to debut at next month's Detroit auto show under the hood of the 2010 Chevrolet Equinox.
Before we delve into GM's expanding lineup of DI powertrains, it's probably best to break down the technology.  Direct-injected motors receive their fuel delivery directly into each cylinder where it first evaporates, cooling the hot compressed air-fuel mixture, which makes it less susceptible to knock and therefore more tolerant of a higher compression ratio.  In regular port fuel-injected engines, the injection and evaporation happens in the intake runner,  well before the mixture inters the combustion chamber.  Generally speaking, the process yields less fuel consumption, equivalent power production and reduced emissions versus not_DI motors.  It also allows for cleaner cold starts through an easier ignition.
In addition to boasting direct injection, both engines utilize variable valve timing on both the intake and exhaust cams to improve performance.  The 2.4L four-banger makes 182 hp at 6700 rpm and 174 lb-ft at 4400 rpm and features a high-compression 11.4:1 ratio for optimal power.  Dished pistons allow increased combustion efficiency, while application-specific injectors automatically modulate fuel flow.  It's based on the existing 2.4-liter, but the block is now sand-cast to improve strength and withstand the higher in-cylinder pressures (the previous engine used a lost-foam casting method).  Its bigger 3.0L V-6 brother (255-hp, 214 lb-ft) is based off the current 3.6L direct-injected unit in the Cadillac CTS and incorporates an isolated fuel injector system for quieter operation.  Rubber isolators are used with the fuel rail to diminish vibration and noise as well.
GM introduced its first generation DI system on a small scale in the 2007 Saturn Sky Red Line and Pontiac Solstice GXP.  For the 2009 model year, six engines in 18 global market models will have the technology, with that number jumping up to eight engines in 38 models by
MY2010.  North America alone will have 18 models featuring DI in the same product cycle.  Along with the 2010 Chevrolet Equinox, the technology will be employed by the 2010 Cadillac SRX and 2010 Buick LaCrosse sedan, both of which are also bowing in Detroit.
To give you a better idea of how significant the potential fuel savings DI helps to achieve, consider these figures compiled by GM bean counters.  The General's 2009 North American lineup will use 700 million fewer gallons of fuel during the lifetime of its vehicles compared with the 2008 group.  That number is expected to hit 1.1 billion gallons for 2010.  Enter into the equation a price of $2 to $3 dollars per gallon, and you get a good indication of the total pump savings.
Even with so much uncertainty and gloom surrounding Detroit and Washington these days, it's a welcome surprise for GM to continue its efforts to push next-generation fuel-saving technologies it its vehicles.  Whether or not this is all too little too late for the struggling automaker has yet to be seen, but we're quite certain it won't hinder its cause."
[End Quote] Motor Trend"
« Last Edit: January 20, 2009, 11:48:08 AM by GXPinKC »
Offline Lucy'sDaddy
    • Lucy's cardomain page
Re: GM's Direct-Injected Engine Future
« Reply #1 on: January 20, 2009, 08:16:12 PM »
What a NOVEL idea! Might have to try one of these things. Oh Ya! BEEN THERE, DOING THAT!
