Author Topic: Going to the track tonight  (Read 3742 times)
Offline 2.0 tspeed
« on: February 18, 2011, 06:13:52 PM »
well lets see what 21 psi can do over my old 26 psi tune.
will post slips up tonight track opens at 630
what do you guys think ill run :-D
« Last Edit: February 19, 2011, 09:17:52 AM by DeepBlueGXP »
2013 verano turbo
Re: GOING TO TRACK TONIGHT
« Reply #1 on: February 18, 2011, 06:23:33 PM »
huh? 21psi over 26psi?
same mods? same tires? same track?
What where your numbers previously?
Offline 2.0 tspeed
« Reply #2 on: February 18, 2011, 06:28:10 PM »
same mods just 21 psi  tune  instead of 26 and dp
same track
same tires
my last average was low 13's at 107
2013 verano turbo
« Reply #3 on: February 18, 2011, 06:29:03 PM »
Lucky! Our local track doesn't open till March...
Those BFG drag radials?
Offline 2.0 tspeed
« Reply #4 on: February 18, 2011, 06:29:56 PM »
street radials
2013 verano turbo
« Reply #5 on: February 18, 2011, 06:30:42 PM »
what 60ft time you got previously?
What is the difference between drag radial and street radial?  :idk:
Offline 2.0 tspeed
« Reply #6 on: February 18, 2011, 06:31:16 PM »
2.2 2.1 blah garbage
2013 verano turbo
« Reply #7 on: February 18, 2011, 06:32:19 PM »
13.5s will be a good time if you will get that one tonight ;)
Track sucks?
Good luck
Offline 2.0 tspeed
« Reply #8 on: February 18, 2011, 06:34:14 PM »
sometimes its good and sometimes its bad. and its always humid and hot.
they spray the water to much and its hard to go around. theres no reason for me to do a burnout
2013 verano turbo
« Reply #9 on: February 18, 2011, 06:36:56 PM »
With those tires you really should do a burnout. A friend of mine was racing the same tire, ditched them for MT's a little while later and was much happier.
« Reply #10 on: February 18, 2011, 06:48:24 PM »
If street radial means street legal tire with race compound, I agree with U238.
I have tried Toyo R888 tires, which are street legal circuit tires, and my 60ft were same as with factory Bridges.
best 60ft times:
- 1.95s with Briges
- 1.94s with Toyo R888 and lighter rims.
I would love to see Nitto NT05R/555R drag radial tested tho.
