Forum > Interior/Exterior Mods
Brake light flasher (kit) ~$15
<< < (5/11) > >>
GASNGO:
--- Quote from: TomatoSoup on February 26, 2011, 04:08:01 PM ---I found a cheap kit for a 3rd brake light flasher, just soldered it together today. Obviously, those not into soldering should read no further :) but it is very easy to build and only basic soldering skills are required.
The kit is the Velleman MK178 and is available from many places online for between $10 and $15 (plus ship) - google MK178.  I got mine from Electronics123.com for ~$18 shipped.  Since I ordered it though, I also found it for $10.69 from arcade-electronics.com in Alexandria VA w/free pickup from the shop if you are local... MK178 kit.
It's not only cheap, but it also has features that I wanted (that most of the cheap pre-built ones don't) incl selectable number of times to flash, and more importantly, a timeout period where it won't flash every time you touch the brakes if you are in stop & go traffic.
Features (I'm quoting here):
    * Easy two-step install
    * makes your 3rd brake light flash
    * selectable number of flashes: 5 or 10 times
    * selectable flash repeat interval: always or not within 5-7sec between two brakes
    * includes shrink tube to cover complete unit
    * flash frequency: 7 times per second
    I have a question regarding the 2 blue pcs. that are next to the time out wording. How did you attach these and are they attached in any special order? I bought a kit and everything else seems pretty straight forward. Thanks
--- End quote ---
TomatoSoup:
--- Quote from: desk305 link=topic=6307.msg91000#msg91000 ---
    I have a question regarding the 2 blue pcs. that are next to the time out wording. How did you attach these and are they attached in any special order? I bought a kit and everything else seems pretty straight forward. Thank you
--- End quote ---
I think youre referring to the jumpers I just talked about above. You solder the posts on and push on the jumpers you need to to select the operation you want. In my case I didn't I use either jumper.
Brad Kenny:
--- Quote from: DeepBlueGXP on February 27, 2011, 10:12:19 AM ---I bought these last year for the coupe and my car, plug and play - no soldering and took only a few minutes to install.  $59 was worth t for no hassles.
http://www.webelectricproducts.com/blp/ssr/blpssrdetails.htm
--- End quote ---
Somehow missed this post a long time ago. Just thought I would thank you Joe for the great idea and the increased safety while stopping. THANKS!!!
TomatoSoup:
This is a response to blewis1, who sent me an initially context-free & thus confusing PM about this.  I tried to respond but his PM inbox is full, so doing it here...  :banghead:
--- Quote from: blewis1 on June 21, 2011, 11:40:37 PM ---do you know the names of some of the other brands mine flashes 3 times it just not enough flashes for me
need names of other high end brands. or regular brands. list as many as you can thanks
--- End quote ---
--- Quote from: blewis1 on June 22, 2011, 12:16:00 AM --- sorry brake light mod
--- End quote ---
Sorry I only have experience of my kit (requires soldering) which is selectable to flash 5 or 10 times.  Then there's the one DBG got that he mentions in post #6.
When I was initially looking I found a bunch on Google, just search for "brake light flashers". Most are for motorbikes, but will work fine on our cars' 3rd brake lights.
Don't know that any are 'brand names'.
SolNut:
--- End quote ---
How tough was the Coupe install???  :banghead:
Steve
Navigation
Message Index
Next page
Previous page
Go to full version
