Author Topic: Clutch question  (Read 7540 times)
Clutch question
« on: March 31, 2011, 03:19:37 PM »
a friend of mine needs to have his GT's pressure plate and disk replaced. furthermore it needs the third thing that we replace in this case. in translation, in greek, we call it bearings.
does that make any sense to you?
i am looking for the correct english word (a picture of the item would also help) so as to look for it in ebay or in a vendor and order it. they ask tons of money here for pressure plate-disk-bearings
thx in advance
Re: Clutch question
« Reply #1 on: March 31, 2011, 03:38:47 PM »
Throw out bearing or release bearing.
Re: Clutch question
« Reply #2 on: March 31, 2011, 04:34:33 PM »
That would normally be correct but the Kappa doesn't have one.  It uses something call an HTC or something like that.  It is a hydrolic release that fits over the transmission input shaft.
Randy and Dave know the actual name of it, I will email them and ask them to stop by and let you know.
Email sent.
Re: Clutch question
« Reply #3 on: March 31, 2011, 04:43:07 PM »
Found it but you have to promise you will not tell anyone I was over on the BB.
Hydraulic Throw-out piston Bearing (HTOB) assembly
Offline Divingsolo (formely Randy@DDM)
    • DDMWorks - Your total Kappa Performance Solution
Re: Clutch question
« Reply #4 on: March 31, 2011, 04:45:57 PM »
Part                                                               OEM Part                       Price
Clutch Slave Cylinder                                         24249824                      $150.56
Part # 2
Randy@DDMWorks.com
www.DDMWorks.com
Re: Clutch question
« Reply #5 on: March 31, 2011, 09:52:26 PM »
you are the man Randy.
Re: Clutch question
« Reply #6 on: April 01, 2011, 02:29:45 AM »
SA, Critter and Randy, thx a lot guys!!
i really appreciate it!!!!
Offline spider
Re: Clutch question
« Reply #7 on: April 01, 2011, 07:47:20 PM »
Turbo & NA use similar but different ones, no?
Re: Clutch question
« Reply #8 on: April 01, 2011, 07:52:42 PM »
correct...different part #'s for turbo vs NA due to differences in the clutchs
Randy@DDMWorks.com
www.DDMWorks.com
Offline Kagem
Re: Clutch question
« Reply #9 on: April 02, 2011, 02:31:01 AM »
Not intend to spam this thread but instead of opening a new one i thought i might ask here. I have the same problem with the car i use for my job, it's a honda civic es 1.6 manual transmission, same as that http://www.car.gr/classifieds/cars/photos/1330541/
Here in honda dealership is way too expensive, anyone knows where can i find honda parts? Thanks....
Re: Clutch question
« Reply #10 on: April 02, 2011, 11:40:16 AM »
Kagem ; I've had to order from this place But my Son use to. Check it out , Hope it helps you
    http://importspartsdirect.com/
Offline Kagem
Re: Clutch question
« Reply #11 on: April 02, 2011, 07:55:20 PM »
Thanks Bobby, i'll check it out! Thank you for helping me out!
Re: Clutch question
« Reply #12 on: April 02, 2011, 09:05:53 PM »
I hope they have what you are looking for at a cheaper price also.
Re: Clutch question
« Reply #13 on: April 03, 2011, 02:30:26 AM »
if you don't find it there Kagem, go to Frantzi street, you will find parts there at good price.
Offline Kagem
Re: Clutch question
« Reply #14 on: April 03, 2011, 07:49:43 AM »
Thanks guys! Your help is vulnerable!
Offline Gregory
Re: Clutch question
« Reply #15 on: April 29, 2011, 10:55:04 AM »
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=330558677389
do you know what this is? Is there a need to be changed when you replace the clutch?
Re: Clutch question
« Reply #16 on: April 29, 2011, 12:07:08 PM »
Not unless it is leaking.  It is external and can be changed when needed.  That is connected to the clutch pedal and pushes the fluid to the slave cylinder (has a different name) that is located in the bellhousing. and releases the clutch.
Re: Clutch question
« Reply #17 on: April 29, 2011, 12:09:27 PM »
It's the clutch master cylinder - the thing that's attached to the clutch pedal and that you compress when you press on the clutch.  That compresses (squeezes) the clutch fluid down the the clutch slave cylinder which opens the clutch.
You only need to replace this if it's broken/leaking, not when you change your clutch.
DANG! Critter beat me to the punch
Re: Clutch question
« Reply #18 on: April 29, 2011, 12:15:16 PM »
Priceless!
Apologies, Kagem, your English is infinitely better than my Greek!  But some typos are unconsciously hilarious :)  I think you meant "valuable" (or maybe you didn't?)
Re: Clutch question
« Reply #19 on: April 29, 2011, 01:55:36 PM »
No, I would say help from some people could be vulnerable.
But I would never lead someone astray...
Oh no wait yeah I would but don't anyone go tell GJ ok. :thumbs:
Offline Gregory
Re: Clutch question
« Reply #20 on: April 29, 2011, 02:55:25 PM »
Thank you guyz :)
Offline Kagem
Re: Clutch question
« Reply #21 on: April 30, 2011, 08:55:42 AM »
 :lol: :lol: :lol: :lol:
You're right TomatoSoap, my typos are sometimes misleading, i wanted to say valuable, i must have been listening to roxette when i was posting, sorry for that! I won't tell GJ, you have my word on this....
Re: Clutch question
« Reply #22 on: April 30, 2011, 10:16:44 AM »
Magen,
Now I'm feeling venerable... Or valuable, I'm not sure.
Offline Gregory
Re: Clutch question
« Reply #23 on: April 30, 2011, 11:46:01 AM »
Kagem, why don't you tell them about your magic potion??? :poke:
