Author Topic: AEM AFR gauge - Need advice with wiring  (Read 2962 times)
Offline salstice
« on: April 09, 2011, 09:38:51 PM »
I am in the process of installing an AEM afr gauge. I've already welded up the sensor bung  to my turbo down tube, installed the sensor, and ran the wire harness through the firewall. I'm now at the stage of wiring up my power source. I need a constant 12v source utilizing a 5amp fuse and a switched 12v source utilizing a 5amp fuse. I'd like to know what people here have plugged into for the power sources. Any help would be awesome!
Offline salstice
Re: AEM AFR gauge - Need advice with wiring
« Reply #1 on: April 10, 2011, 09:13:06 AM »
Anybody?
« Reply #2 on: April 10, 2011, 11:45:35 AM »
Here is how I hooked power source for my boost gauge:
http://www.kappaperformance.com/forum/index.php/topic,4343.0.html
Offline Graywolf
« Reply #3 on: April 10, 2011, 05:35:09 PM »
The electrical power source is found passenger side inside the car where you would brace your feet if your wife was driving your car. The panel pulls out for easy access. I use this source for my AEM boost gauge, oil temp and oil pressre gauges. This is how Dave at Performance Autowerks does it since he did not like my original way for my boost gauge electrical source.
Offline salstice
« Reply #4 on: April 11, 2011, 12:40:07 PM »
Thanks for the help guys! I got it figured out yesterday. The AEM wideband has two red wires for constant power, a pink for switched power, a black for ground, a grey for dimming, and white/brown for data logging.
I hooked up the red wires to the rearview mirror since it was the only thing in the cabin that had a constant feed and a 5amp fuse. I wired the pink wire to one of the empty slots on the BCM. The grey went to the power supply on the backside of the gauge cluster (which was also grey). I grounded the black to the ground location under the arm rest.
Gauge works awesome! :yay:
« Reply #5 on: April 11, 2011, 01:48:24 PM »
Tadaaa  :devil:
 :ttiwwp:
Offline Graywolf
« Reply #6 on: April 11, 2011, 11:38:05 PM »
Kelu, wheres your imagination. Pics are for kids!  Since I never post pics,I have to defend Salstice! Glad your gauge is working with your creative wiring system.
Offline salstice
« Reply #7 on: April 13, 2011, 01:12:53 PM »
Tadaaa  :devil:
 :ttiwwp:
I know, I know......
The projects I plan to do how-to's/pictures don't ever seem to work out right.
And then the projects that do work out right (like this one), I forget to document.
UHHHHH!
« Reply #8 on: April 13, 2011, 01:16:38 PM »
You know when you finish a mod, you can always undo some things and document it :P
Offline idkfa
  • Violent Jain
  • mostly harmless
    • Make
« Reply #9 on: April 22, 2011, 06:28:08 PM »
Hey, so the empty slots in the BCM get power as well?  Did you install a 10a fuse?  Does it matter which?
I tried running mine off the 'Cluster' 10a figuring that only gets power when the key is turned but the gauge never shut off.  Anyone have a good suggestion?
The ground spot under the arm rest was perfect though.  Thanks :)
[edit]  awesome:
http://www.kappaperformance.com/forum/index.php/topic,1740.msg18819.html#msg18819
