So I bought a cheap Blue Tooth OBD link and installed Torque. It looks like you can data log any custom PID's which is pretty cool. Torque calculates HP torque at the wheels using Accelerometers and/or GPS in your phone. A couple early observations is that the HP and torque numbers seem lower than expected based on my setup, though it is hard to get more that 300 hp at the wheel before my eagle F1's squeal (which affects hp/torque calcs). The second observation was the intake air temperature is 40-50 degrees more than ambient air temp (if I recall correctly), I'm not educated on what should be expected yet, but it makes me ponder if my hahn fmic isn't clogged with oil (something perhaps to look at after occ is installed).
Anyone using Torque, or can suggest a typical set of pids to log for general performance/health? Anyone know the correct pids for knock retard?
