Author Topic: p0010 code  (Read 2301 times)
Offline hammy221
p0010 code
« on: June 04, 2011, 07:11:33 PM »
i know the code is  Camshaft Position Actuator Circuit (Bank 1) anyone ever come across this and if so what did it turn out to be?? i know it could be Faulty oil control valve (OCV)
Open or short in the VVT/VCT circuit  Open or short in the OCV / solenoid valve Damaged computer (PCM). car runs fine so damge to the pcm i dont think it is. what exactly is the OCV is it the solanoid on the top if the engine in the front??
Re: p0010 code
« Reply #1 on: June 04, 2011, 10:36:42 PM »
Easy thing to check first is your oil level. Low oil can trigger this.
Offline hammy221
Re: p0010 code
« Reply #2 on: June 04, 2011, 10:50:21 PM »
makes sence i just have the front cover off along with the oil pump. oil level is good might of been love in the vvt system its not coding anymore.. thanks for the info
Offline S.P.
Re: p0010 code
« Reply #3 on: June 04, 2011, 10:52:55 PM »
I had this problem a while back. Installing a new camshaft solenoid solved the issue for me. The part is fairly inexpensive and easy to replace.
