Author Topic: GT2871 with Synapse BOV- Issue at Idle and Low Speeds  (Read 45321 times)
Offline IBDRINKEN
  • Donkey Master
Re: GT2871 with Synapse BOV- Issue at Idle and Low Speeds
« Reply #100 on: June 16, 2011, 10:56:26 PM »
Please explain to us that are thinking about the turbo upgrade what exactlythe fix was...   :donkey: I just had to use it lol....
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
« Reply #101 on: June 16, 2011, 11:04:03 PM »
Love it!  :donkey:
« Reply #102 on: June 16, 2011, 11:15:38 PM »
What exactly was happening?
At idle, if I revved the car enough for the BOV to release, it would release two times, one following the first release.  After adjusting the spring tension, it went away and still releases cleanly under load.  It took a lot or trial and error.
« Reply #103 on: June 16, 2011, 11:36:43 PM »
I am assuming by tightening it?
« Reply #104 on: June 17, 2011, 12:25:54 AM »
Yessir...about 1 3/4 turns.
« Reply #105 on: June 17, 2011, 05:57:31 AM »
Great! Glad you got the double actuation out.... Hopefully the anti-stall will get rid of your RPM drop and you should be enjoying your kappa's new found power :)
« Reply #106 on: June 17, 2011, 08:42:56 AM »
I was enjoying it yesterday...on the way to the beach there is some open highway and I just decided to have a little fun...going from 60-110 was unreal...so fast...maybe 5 seconds or so...if you don't pay attention, you won't realize how fast you are going.
« Reply #107 on: June 17, 2011, 08:56:01 AM »
it just occured to me that a guy  here in Greece has added the Synapse BOV to his GT (stock turbo) just for the sound. he put it in the cold side pipe and he hasn't mentioned any problems with it.
however he just received the anti stall valve which he will add to it...don't know why, but he will let me know
« Reply #108 on: June 17, 2011, 09:33:08 AM »
Arabas
It's because his Rpms were dropping.
Same issue Steve and myself are having.
Miller,
Can you post a pic of the connector between the turbo and passenger IC pipe.
I'm curious as to what yours looks like since the BOV in your install is on the driver IC pipe.
Thanks
« Reply #109 on: June 17, 2011, 09:43:36 AM »
Looks just like your Dejon pipe with a synapse flange welded on it. Same as ROXA on the sky forum
I will get you a pic later on today tho :D
« Reply #110 on: June 17, 2011, 09:46:11 AM »
+1
Ive already caught myself doing 115+ and didn't realize it when coming on an on-ramp.  I will be going to the track today to find out more on this (assuming they stay open for business tonight)
« Reply #111 on: June 17, 2011, 09:54:06 AM »
I know that.  Which is why I asked for a picture of a different part of your engine bay
 :slap:
Quote from: FiestyLittleDude
« Reply #112 on: June 17, 2011, 09:56:10 AM »
Arabas
Miller,
Thanks
he said that the rpms on idle were steady....
i must learn more and let you know guys
« Reply #113 on: June 17, 2011, 10:11:42 AM »
On idle maybe, but what about after revving it and under a slight load at low speeds?
« Reply #114 on: June 17, 2011, 10:45:51 AM »
 :slap: :D
Its connected to the boost control solenoid that is on the engine block... not the turbo. ;)
I have one piece of vac line from the solenoid to the back of my BOV. It is split with a T fitting and the two lines go on both ports.
« Reply #115 on: June 17, 2011, 11:03:10 AM »
You got held back alot in skul didn't you?
iHawk..........HELP!!!!
To Paraphase
What does the elbow from the Turbo to the Passenger IC Pipe look like in your setup?
Steve and I have the BOV in between those 2 like in this picture.
« Reply #116 on: June 17, 2011, 11:20:43 AM »
Oh hell no!!!  Lesson learned!  Besides, I couldn't tell ya.
Good luck elff!
Wait...can I use this?   :donkey:
I just wanted an excuse to use the new smiley!  No reason for it...I just like new smiley choices!
« Last Edit: June 17, 2011, 11:49:29 AM by ihawk95 »
« Reply #117 on: June 17, 2011, 11:39:37 AM »
its just a friggin piece of pipe.... no flange
Sorry been a lot going on at work today... ill get a pic up soon to FB. and hopefully someone can link it for ya..
Like I said im going to the dragstrip after work. :)
« Reply #118 on: June 17, 2011, 04:37:57 PM »
Elff - Here is a picture of the "friggin piece of pipe" from Mr. Miller.
This post approved by Chris Miller
« Reply #119 on: June 17, 2011, 04:44:16 PM »
my greek GT friend with stock turbo and Synapse, had the exact same little problem as you describe guys and he just received today his anti stall valve.
he was kind enough to make a pre and after video that will help a lot of people understand the nature of the problem.
as he describes it, when air exits in volume through the bov all is ok, but in the end the bov stays open to let just a little bit of air out. At that time air from the atmosphere finds the opportunity to enter and causes this little rpm drop.
without anti stall valve
WITH anti stall valve
« Reply #120 on: June 17, 2011, 04:46:56 PM »
Just put my anti-stall valve in as well, and the problem is gone:)
The same before and after as the video above!  I am very happy!!  These need to come with the 2871 kits!
« Reply #121 on: June 17, 2011, 05:44:46 PM »
Holy crazy end of day.
Got your message Steve
My Anti Stall is installed, I didn't hold down the piston to install it, so I am not sure how ON it actually is.  Should be alright I think.
 :idk:
I would have like to heave heard the difference in the BOV, vs just watching the RPMs.  Music was too loud in the first one.
I am still getting a weird noise, but it's coming out of the Dejon Intake on the release of the Air.
Similar to how it changed when I added the intake and eliminated the stock intake.
So I don't think it's an issue.
Will relay my results as well.  Time to walk the Puppy.  She is bugging me to go out.
« Reply #122 on: June 18, 2011, 12:53:48 AM »
 :idk:
The anti-stall valve seems to have made it higher pitched.  It is still loud.  I did not hold the piston either, but it seems to be on there pretty good...I turned it until it just kept turning without going in anymore.  No more hesitation or dip in RPM's.  Sounds like you might have an intake issue??
« Reply #123 on: June 18, 2011, 01:18:40 AM »
Glad this worked!
Maybe they should be standard for the 2871 kits?
« Reply #124 on: June 18, 2011, 01:20:36 AM »
It is standard with this kit for an additional $39.99.  You bought the right kit Miller.  It's the other two clowns that bought the "incomplete" kit.
goof balls.
