Author Topic: Boost leak from popped line of analogue boost gauge  (Read 3919 times)
« on: June 17, 2011, 05:10:42 PM »
Since i found and fixed the problem, i can laugh about it now...
so, this will be a quiz (if you don't mind, i will change the title after the brainstorming).
if you have a moment to spare and to think a bit about it, pls write what you think my car's problem was
i was driving the highway and a Subaru Forester Turbo with a woman driving was right on my tail and wouldn't let go.
sure i went crazy, let her come side by side and stepped on it just to smoke her one time after another till she had enough (XXX km/h)
i soon got off the highway and came to a complete stop just to notice that my idle was at 1000rpm. stepped on the gas a few times but the problem remained. also the rpm were not dropping easily when i let my foot off the gas.
checked my analogue boost gauge and it showed 0 psi when i stepped on it.
my dic was displaying coolant temps at that time and temps were OK. no CEL. car felt it had power even though i decided not to WOT till i got home safely
i started something like " this  :censor: car", "i am selling it", " :mad:", " :censor:"
i had this idea of what could be wrong and i tried something while driving that showed me that the car had indeed power. got home, idle was still at 1000 rpm.
fixed the problem easily and i decided no to sell it  :woohoo:
so, what do you think had happened?
what would you check first, second etc etc?
« Last Edit: June 18, 2011, 04:51:16 AM by Arabas »
Re: What do you believe the problem is?
« Reply #1 on: June 17, 2011, 05:15:53 PM »
I think you sucked up a bag and clogged your intake.
Either that or your girlfriends head was stuck under the steering wheel and her hand was on the gas pedal?
« Reply #2 on: June 17, 2011, 05:16:30 PM »
Bubble gum stuck on the gas pedal LOL?????
« Reply #3 on: June 17, 2011, 05:20:22 PM »
pfff...not close guys.
i kept thinking of elff, steve and miller (and i don't mean sexually GJ) when i saw my idle rpms at not normal level
« Reply #4 on: June 17, 2011, 05:34:38 PM »
maybe this... :donkey:
Offline Gregory
« Reply #5 on: June 17, 2011, 05:38:36 PM »
First of all George, you cannot sell the car because no one would ever buy that thing! I wonder how you still call it a car :poke:
So was it something in the fuse box :huh:
Shall I call you to tell me and then write?
2008 Opel GT, Black, Trifecta tune, 200cpi SOLO DownPipe, K&N Air Filter, 4piston Brembo front brakes with EBC yellowstuff brakepads, DDM Backbone and ProBeam, LatinVenom Front Chassis Brace. NEXT STEP: Install the SPEC stage 3+ Clutch kit and Flywheel ;)
« Reply #6 on: June 17, 2011, 05:47:54 PM »
The wastegate nut backed out.
I knew I felt dirty today.
« Reply #7 on: June 17, 2011, 06:13:19 PM »
A woman on my tail raises my idle speed!!!!   :devil:
No, seriously, floor mat messing with the gas pedal.   The Honda problem.
« Reply #8 on: June 17, 2011, 06:53:19 PM »
Something got stuck under your gas pedal, something flexible like floor mat as Treeman was saying or a pack of cigarette.
« Reply #9 on: June 17, 2011, 07:39:56 PM »
You put on your platform shoes this morning and were pushing the pedal without realizing.
« Reply #10 on: June 17, 2011, 07:44:15 PM »
You blew the line for the boost gauge off and ended up with an intake leak which caused the high idle RPM.
« Reply #11 on: June 17, 2011, 08:06:03 PM »
I think SA is close, you blew a line or a tube loose and had a vacumn leak
« Reply #12 on: June 17, 2011, 09:38:14 PM »
THat's the one I would have thought.
Had that happen on my Ford truck and IM like OH Shat I cant stop as I almost rear end a Focus.
Offline baconbits
« Reply #13 on: June 17, 2011, 10:57:51 PM »
Demonic Possession...
« Reply #14 on: June 17, 2011, 11:33:32 PM »
 I think a vacuum line came off or developed a leak and raised the RPM level .
« Reply #15 on: June 17, 2011, 11:57:21 PM »
Just reread his original post and.....
Vac boost line popped off the analog boost gauge causing it to read 0 psi when in boost causing a slight vacuum leak thus raising the idle speed?
Winner Winner chicken dinner?
« Reply #16 on: June 18, 2011, 03:23:16 AM »
That theory sounds familiar I wonder who may have already said that... :kwh:
« Reply #17 on: June 18, 2011, 04:49:51 AM »
we don't have one, but 4 winners!!!!  :thumbs:
SA, Critter, 1LILNDN, and Tazz nailed it!!
you can add this one to the list of your overseas diagnosis!!!
since i have the analog boost, i have my DIC always on coolant temp.
when i saw 0 psi on the analog gauge, i turned the DIC on the boost gauge mode. it showed real boost.
so i thought the analog boost gauge line had popped off. popped the hood to find that was indeed the reason.
boost leak from the popped line of the gauge.
put it back, tightened it with a zip tie. idle back to normal!!  :yay:
easy fix, reasonable diagnosis. glad i didn't get too pissed to throw the car off a cliff!
so, slightly raised rpms at idle should be a syptom of any simple boost leak.
« Last Edit: June 18, 2011, 04:56:54 AM by Arabas »
