Author Topic: Z0K springs  (Read 2989 times)
Offline cbr6
Z0K springs
« on: June 19, 2011, 07:30:35 PM »
  Hello, does anyone know about how much just the Z0K GXP will lower a GXP?  thanks
Re: Z0K springs
« Reply #1 on: June 19, 2011, 07:37:23 PM »
Off the of my head no
But if you do a search you should be able to find it.
Numerous people have done that swap.
The most recent was Gentleman Jack.
Re: Z0K springs
« Reply #2 on: June 19, 2011, 07:46:21 PM »
Just did this a week ago. The springs still need to settle a little more, but let me run put and get some current readings.  Hold tight.
Ok, just got back in.  I measured up from the ground, through the center of the wheel to the fender.
Front 27.5"
Rear 28.5"
For me, that's a 0.5 inch drop all around.  It's been about 150 miles, so I'm not sure they will drop much more.
See my instal thread here:
http://www.kappaperformance.com/forum/index.php/topic,7280.0.html
« Last Edit: June 19, 2011, 07:54:57 PM by Gentleman Jack »
Offline cbr6
Re: Z0K springs
« Reply #3 on: June 19, 2011, 10:18:56 PM »
Thanks, I was concerned about getting to low with springs and koni sa's. I had several great emails with snap on bob, but then I confused my self when I found out thes koni's are 15mm shorter. again thanks guys.
Re: Z0K springs
« Reply #4 on: June 20, 2011, 08:44:51 PM »
It is suppose to give about a 7mm drop.
Re: Z0K springs
« Reply #5 on: June 20, 2011, 09:04:14 PM »
Not mine !!!! Besides, once they are mounted and the car is on the ground, it does not matter. The springs will be doing the work of holding up the car, not the shocks.
