Author Topic: FYI - Removing pins from GMPP TMAP connectors  (Read 10431 times)
« on: July 04, 2011, 12:48:59 PM »
As some folks witnessed at MMM8, the &**%^%$ dealer that sold me my car (no longer in business) installed my GMPP tune and made a butchered job of it.  They managed to cut one wire too short (I assume) and crimped it TWICE, in two different places. Of course they covered-up the <excrement> work with tape, so I didn't find this until I went to solder the connections after I got a code one time.  I was so stunned I just recrimped, which fixed the code, and went away to regroup.
[attachment=1]
Then I investigated getting a replacement connector to solder with, but found they are over $70 each!  For a %^%$ connector!  The TMAP sensors themselves, are only a FIFTH of the price of the stupid connector!
SO, yesterday I decided to go ahead and cut off the connectors and see if I could swap the unused pin and pigtail wire with the hashed-up one, hopefully avoiding the need to solder that wire twice.  After a lot of investigation using a Jewelers loupe and mini-maglight, I worked out how the pins were held into the connector shell.  By way of background, most pins like this are held in with one, or sometimes two, spring-tabs that lock behind a ridge in the plastic shell.  I found that THESE pins have FOUR spring tabs. (Ay caramba!)...
[attachment=2]
If you should ever need to remove one (hopefully you won't) you'll need to insert a fine probe such as a sewing needle (note: dental probes are too big) into the holes shown by the arrows and bend the tabs down to free the pin...
[attachment=3]
One more tip for those soldering their connectors... You can cut the crimps off on either side of the metal crimp-tube in the middle, leaving the ends of plastic outer shell still on the wires.  Although these are glued on, you can then remove them using a mini-butane torch to soften the plastic and then slide off the wire with needle-nosed pliers.  This will give you as much wire as possible on either side to solder with.  Be careful not to melt the wire insulation though!
Re: FYI - Removing pins from GMPP TMAP connectors
« Reply #2 on: July 04, 2011, 03:10:34 PM »
That's a lot more reasonable.  But good write up TS.   It's amazing what you have to go through sometimes, because someone you paid to do something correctly, half @$$ed it.
U R da man
« Reply #3 on: July 05, 2011, 10:32:18 AM »
I am not looking forward to soldering mine. Not sure what I'll find!
« Reply #4 on: July 05, 2011, 10:42:01 AM »
I got lucky.  Had about 3" of extra wire on the connector side.  hopefully you will have similar luck.
Offline flyingfish
« Reply #5 on: July 05, 2011, 07:27:30 PM »
My brother has special tools that are made to remove the pins from the connectors.
