Author Topic: Pro-Beam Installation  (Read 1426 times)
Offline Sbutcher2
« on: July 25, 2011, 04:40:55 PM »
So glad that I installed the Pro-Beam. the suspension is now more solid, especially since I already had the center brace. The installation was easy and directions were very good. I recommend the use of lock washers just to be sure to keep everything tight. There were no problems with clearance on the 3 in Magnaflow exhaust. I am looking forward to get the Sol on the autocross to feel if the car has lossen up a bit.
 :drive:
« Last Edit: July 25, 2011, 07:48:12 PM by DeepBlueGXP, Reason: changed title to lower case »
Enjoying the open ride.
Offline GaryDN
Re: PRO-BEAM INSTALLATION
« Reply #1 on: July 25, 2011, 07:23:20 PM »
did my recently too Steve, it does make a difference.  I have the center stack exhaust and had no problem installing it
2009 GXP Wicked - all the toys I could find
2007 NA Deep - Traded in 5/13/09
Offline Sbutcher2
Re: Pro-Beam Installation
« Reply #2 on: July 25, 2011, 08:46:13 PM »
Gary, glad that you had the same seat of the pants dino after ther Pro-beam was installed. It is a more solid feel and steering appears to be crisper. I have yet to drive hard into a tight turn to see if the car pushes with too much speed.......... I 'm thinking of Deven's in August.
« Reply #3 on: July 25, 2011, 09:44:44 PM »
You should be getting better traction as well.
What tires will you be using for the AutoX?
Offline Sbutcher2
« Reply #4 on: July 26, 2011, 09:39:20 PM »
HI Dave,
Thanks again for welcoming me into the Kappa Perfomance Network.
I have run a handful of events on the stock F1 Eagles. The first time throught the course with an instructor in a drivers school it was amazing how the car would push through the corners. With some practice and air pressure adjustmentns last year I did some respectable times for a novice.
