Author Topic: Left headlight  (Read 938 times)
Left headlight
« on: September 08, 2011, 09:14:55 PM »
The other day I saw my left Headlight was Dim though it was blowing out . Got a set of Ultra silverstars H 13s. Installed and it is still Dim . Checked the fuses under the Hood  all good .Only the Drivers side .,Could it be a Bad ground ? I'm Stumped.     :banghead:      :gaah:
Re: Left headlight
« Reply #1 on: September 09, 2011, 12:17:56 AM »
You need to use a VOM and check the voltage at the light also check the resistance of the ground wire.
Re: Left headlight
« Reply #2 on: September 09, 2011, 12:38:06 AM »
If its not raining i'll do that in the morning  .   Thanks S/A  are the (4) 10 amp Fuses under the hood the only ones ? L hi beam  , L low beam , R hi beam , R lo beam . #s  63,65,66,67
