Going to lunch today, backing out, slightly uphill, curve on one side, pickups behind me so I was at an idle. And of course I stalled.
Cranked it back over and it sputtered but did not start. Tried again - nothing. Third time I floored it like it had a carb and was flooded -
bad mistake don't ever do this at home.Fired right up and then started running like it was on 2-3 cylinders, could not clear it, no power nothing. Got out of the middle of the parking lot, shut it down. Restarted it normally - same issue. Tried again, no improvement. Went to the diagnostics mode on the dashhawk and had a P0068 code, to clear it I had to shut the motor off.
Cleared it started the car and it has been fine since. Leasons learned:
1. Don't stall the car
2. Never ever touch the gas on a computerized fuel injected car when you are starting it.
