Background:
Due to the consistent water pump failures across both platforms, I watch my coolant resevoir like a hawk. Everytime I pop the hood for cleaning, oil change, anything; I check the resevoir level.
About 1500 miles ago (before my Atlantic rounder to see the boys), I have an oil change done, check the fluids. Good to go...
Have not had the hood up since. (approximately 10 days).
This morning I go out and stick the key in, start the car and immediately get the low coolant light. WTF?!?
Stop the car, pop the hood and sure enough, fluid level is at the bottom of the resevoir tank, but not below the indicating range. (no air introduction).
Fill with DI water to the normal line (20 oz of water), drive to work. Of coarse I am now running late, so I pop into work, do the morning meetings, and at first chance pop the hood and find the level down about 1/4 of the resevoir level again. No fluid on ground, no sign of a hose or clamp failure.
I call the dealership, maybe we can look at it Monday or Tuesday. Grrr...
I wait another hour, check the fluid level, no change. I start the car and run it at idle for about 10 minutes, no visible leaks, no noted drips from the water pump or hoses. Distinct smell of DEXCOOL. Check the tail pipes, no white smoke, could tell you if there is a smell of coolant or not. Water level rises a little (due to heatup, normal) in the resevoir.
So hear I sit, trying to find a dealer who will take a look at it. before next week. (Have a trip to DDM for other installs in 8 days).
My first thought is water pump, some have had it intermittently dump fluid and then stop, others complete failure. I would be happy with either since I only have about 4 years and 57k miles (covered by powertrain/engine warranty). Other thought, water jacket or head gasket failure.
What should I be looking for? Obviously puddles, leaks, hose failures, coolant level etc. But what about the other (head gasket, jacket failure)?
Thanks for you input in advance. Hammy221, I know you have done this repair yourself, up for another one?
Now I am going home to remove my LV Brace and reinstall the stock air box baffle for a trip to the dealership. Will keep everyone informed of the outcome, if more occurs.
