P2138: Accel Pedal Pos (APP) Sensor 1-2 Correlation
I've been intermittently popping this fault for the past month. It began when I found a harness and idler pulley chaffing. The chaff wrap and a bit of insulation was worn through but no wires were showing. Pic:
Uploaded with
ImageShack.usTo me that didn't seem like enough damage to cause any issues. I replaced the accelerator pedal assembly and all was well for a few weeks, then the code returned. I've also exhausted the following fixes that worked for others:
Replaced throttle body
Cleaned/Applied dielectric grease to APP Sensor, Purge Solendoid, Throttle body, and MAF connectors.
The only thing I haven't checked is the Instrument Panel (IP) to body harness connector. Does anyone know where I can find this? Could that small chaff spot on the harness really be the root cause?
