Author Topic: WERKSracing LNF Long Block Assemblies now available!!!  (Read 1319 times)
« on: November 02, 2012, 05:38:27 PM »
Our new WERKSracing LNF Long Block Engine Assembly is comprised of the latest in engine building technology and WERKSracing development products.
The WERKSracing LNF long block engine assembly comes standard with the following services and components -
Cylinder Head -
WERKSracing high rpm single valve springs
WERKSracing MLS head gasket
WERKSracing high strength timing chain tensioner
ARP head stud kit
New GM valves, seals, direct injectors and high pressure fuel pump
New GM camshafts, cam gear phasers, cam solenoids and timing chain and guides
Short Block -
WERKSracing balanced rotating assembly
Wiseco Forged LNF turbo pistons
Carillo Forged A-Beam connecting rods
New GM main and rod bearings
New GM oil pickup, water pump, seals and oil pump/front cover
New GM Timing chain and balance shaft guides, balance shafts, tensioner and balance shaft chain.
New oil filter
Comes with a 1 year parts only warranty
WERKSracing 2.1L LNF with WERKSracing WR-2 turbocharger -
Please allow 3-4 weeks for assembly
