Author Topic: New Product Announcement - WERKSracing High Strength LNF Timing Chain Tensioner!  (Read 3262 times)
We are proud to release our new WERKSracing Ecotec High Strength Timing chain Tensioner!!! :yay:
Designed to aid high rpm/high pressure (accel) and low oil pressure (decel) timing chain scenarios as encountered when using stronger valve springs.
Features -
New GM LNF Timing chain tensioner
Modified in house for high strength use
Comes with new oil seal ready to install
Works on ALL Ecotec engines
Available here for $149.99 - http://www.performanceautowerks.com/catalog/product_info.php?products_id=1943
  • Lifetime Supporting
    • Ryuk
The stock one definitely seems to be a weak point for those of us who Rev the crap out of our engines.
How exactly is this modified?  I thought the oil pressure pretty much auto engaged this to the proper tension.
We modify the spring pressure internally and yes you are mostly correct, under rpm where the engine is producing strong enough oil pressure the tension is usually fine with the OEM tensioner specs.  However once oil pressure falls off, such as off throttle decel situations or possibly a high G corner (We have seen this on our time attack car at 1.6+Gs) chain tension can drop dramatically to the point where we have seen chains jump a tooth or 2.
Also when you add in stronger valve springs they create more tension on the chain as well and in extreme situations can collapse the tensioner a bit under very high rpm.  We stiffen the spring loaded portion of the tensioner so that when/if oil pressure falls off significant chain slack cannot occur and lead to jumping timing teeth.
Also we have seen competitors go to a modified fixed style of tensioner which in my oipinion is not correct as well.  It puts too much stress on the timing guides and can cause failures due to the design.
Hope that helps...
    • Ryuk
Very much so.
Thank You.
Offline blackbirdracing
  • Kappa Newb
Like the title...
"LNF tensioner"
Later you say.
Fits all ecotec. Lol
Yes, it does fit all Ecotecs.  A lot of LSJ Ecotec guys use the stock LNF tensioner as an upgrade the theirs...
Like the title...
"LNF tensioner"
Later you say.
