Author Topic: Performance Autowerks BLACK FRIDAY WEEKEND SALE Continues-Valve Springs 50% off!  (Read 1476 times)
WERKSracing LSJ, LE5 and LNF Single Valve Springs - Half Price!!!  :yay:
WERKSracing Single High RPM valve spring kits have been tested to sustained 8000rpm in road racing applications and 8500rpm in drag racing applications.
Unlike other spring manufacturers ours are made right here in the USA by the same team that makes the valve springs for the Katech C6r LeMans Corvettes and GM Racing.
Features -
Drop in replacement, utilizes OEM seats, retainers and keepers
Tested up to 8500rpm!!!
16 springs included in the set
Black Nitride finish
80 lbs @ 1.290
Get yours here - The Home of WERKSracing products!
Offline cdflint
Wow, that's an awesome deal. Dang it, dang it, dang it!!! I'd like to buy but my Sol spend account is dried up for the year.  :gaah:
Wait... Christmas list... Telling the wife now.
Questions:
1.  Are the OEM seats, retainers and keepers able to handle the extra performance?
2.  When dropping these in, will a stock or tuned stock turbo be able to get to the higher RPM's or is more for upgraded turbo's?
3.  Since I do most work myself, is there instructions or settings to help with the install?
4.  When opening up, is there any other parts that should be purchased with this?
She's an 09 Brazen GXP.
Covered by Norms Fiberglass, DDM, WERKS, KappaSphere, Trifecta performance, Dejon performance, Solo performance, Magnaflow, Hahn, VDI, B&G, ASAP, WindRestrictor, Gravana, JPM, Santana, Madmod, HID pro, Second Skin Audio, mydipkit, Automotivetouchup.com and soon to be EDAG customized.
Great questions and to answer your questions -
1) Yes we have installed dozens of these valve spring sets on both street cars and track cars retaining the OEM keepers, seats, seals and retainers and have yet to have a failure.  The OEM retainers are very strong.
2) The stock turbo will run out of flow before you are able to maximize the added rpm that the valve springs can give you.
3) No instructions are provided, these are meant to be installed by a professional mechanic or someone who has a great deal of experience installing valve springs in the past.  If you are going to do it yourself I suggest obtaining a factory service manual and following the procedure in the manual.
4) I would reccomend the following parts be repalced at the same time -
LNF Valve cover gasket set - http://www.performanceautowerks.com/catalog/product_info.php?products_id=1838
WERKSracing Ecotec High Strength Timing Chain Tensioner - http://www.performanceautowerks.com/catalog/product_info.php?products_id=1943
LNF front cover gasket - http://www.performanceautowerks.com/catalog/product_info.php?products_id=1826
LNF Cam bolts x2 - http://www.performanceautowerks.com/catalog/product_info.php?products_id=1951
LNF balancer bot - http://www.performanceautowerks.com/catalog/product_info.php?cPath=334_387_392&products_id=1831
NGK Spark plugs - http://www.performanceautowerks.com/catalog/product_info.php?cPath=334_165_370&products_id=1933
« Last Edit: November 24, 2012, 03:51:32 PM by werks »
Updated with all of the reccomended install parts!
