Author Topic: WERKSracing WR-3 Turbocharger official release!!!  (Read 3317 times)
« on: December 11, 2012, 03:31:29 PM »
We are proud to release our newest bolt-on LNF turbocharger, the WERKSracing WR-3!  The WR-3 is our next iteration of our popular WR Series bolt on LNF turbochargers and supports up to 525whp!!!;)
Pictured Above - Optional Compressor housing powder coating, Forge Bypass valve and Type-S 4" inlet 2.5" outlet compressor housing option.
Features -
Stock appearing exhaust housing for a completely bolt on upgrade!!!
Supports up to 525hp!!!
Exhaust side Black Ceramic Coating included in price!!!
Core exchange program
Quick spool and response
55mm leading edge technology billet aluminum compressor wheel
56.5mm exhaust turbine wheel
Internal WG actuator included
Comes complete with all necessary lines and fittings
Compressor housing powdercoating = $50.00
1 year warranty from the date of purchase
2-3 week current build time.
Purchase your WR-3 turbocharger here - The Home of WERKSracing products!
  • Lifetime Supporting
Re: WERKSracing WR-3 Turbocharger official release!!!
« Reply #1 on: December 11, 2012, 05:46:52 PM »
Dave.
If you take the Type S 4" Inlet 2.5 oulet compressor housing option. Can I still use the OEM intake CAI hose?
« Reply #2 on: December 11, 2012, 07:34:23 PM »
The WR-3 requires an aftermarket intake pipe of some sort.  The smaller compresor cover still has a 3" inlet.
Offline jae
« Reply #3 on: December 16, 2012, 01:11:43 PM »
How does the spool up compare to the stock K-04 and the WR-2?
FP 68HTA Turbo
Forge adjustible BOV (recirculated)
Solo hi-flo cat downpipe & Mach Shorty 3" catback
Trifecta max tune
Hahn IC
Dejon Intake and pipes
Offline jae
« Reply #4 on: December 16, 2012, 01:24:42 PM »
Also, Can you speak to potential surge?  Working with 91 octane here in Az with stock internals, so I wont be pushing this thing too much (400whp goal).  Its a step up from my current set up and should add 50whp in the end I hope.  I plan to replace the valve springs and up the redline to 7500 when I do the upgrade.  I may also look at an automatic meth injection system if needed to get to 400whp.
FP 68HTA Turbo
Trifecta max tune
Hahn IC
« Reply #5 on: December 16, 2012, 01:36:27 PM »
No surge on any of our WR series turbochargers.  You will most likely need the water/meth injection as well, straight 91 octane really bites!  Even if you don't I highly reccomend water/meth injection due to its great cleaning properties on the engine internals specifically on the intake valves themselves.
« Reply #6 on: December 16, 2012, 01:38:55 PM »
Spool time is increased a bit over the WR-1 and WR-2.
We saw 20psi at 3950rpm on a Balt SS we tuned last Thursday using our WR-3
Offline jae
« Reply #7 on: December 17, 2012, 10:17:19 PM »
Agreed on 91 octane but thats what I got to work with.  I will look into the meth systems sooner rather than later.  Glad to hear surge is not an issue.
FP 68HTA Turbo
Trifecta max tune
Hahn IC
