Author Topic: 11whp gain using the WERKSracing Phenolic Spacer Set!!!  (Read 8045 times)
  • Lifetime Supporting
Re: 11whp gain using the WERKSracing Phenolic Spacer Set!!!
« Reply #25 on: October 10, 2013, 11:51:07 AM »
I notice a differance in heat transfer but don't know what the added HP differance is.
« Last Edit: October 10, 2013, 06:13:09 PM by 1 LIL NDN »
Offline Omiotek
  • Performance Autowerks
« Reply #26 on: October 10, 2013, 11:39:07 PM »
Less heat transfer = cooler air charge(more power for longer) :)
That to me is the biggest gain over a HP gain. After a track session the intakes warm and so is the throttle body but you can touch it unlike when you do not have the spacers and its ridiculously hot.
 Anyone need a how to on this? im thinking of doing on here for the guys that need it.
Offline spartan
« Reply #27 on: October 11, 2013, 08:31:04 AM »
That would be fantastic.  I might try to tackle it myself if I had a how to.  Parts have been sitting for over a year!
« Reply #28 on: October 11, 2013, 01:16:36 PM »
I have to say You do notice a differance and a cooler manifold . Mine was done in Flagstaff,AZ in June,2013 . I think it is worth doing .
Offline Omiotek
« Reply #29 on: October 15, 2013, 12:42:46 AM »
Its a cheap mod... Totally worth doing imho.
« Reply #30 on: October 16, 2013, 11:20:29 AM »
So I have to ask if the spacers helps to keep the intake manifold and throttle body cooler, is that reflected by the engine temp indicator?  I'm guessing no, but wanted to verify.
« Reply #31 on: October 16, 2013, 10:41:38 PM »
ChopTop
            I have the spacers and it does have a cooler to touch , but the temp is through the block and my temp reading is always about 194*
