Kappa Performance Forum
Kappa Specific => Drive Train and Suspension => Topic started by: Brazen17 on July 31, 2010, 10:04:09 PM
Title: Trans. fluid
Post by: Brazen17 on July 31, 2010, 10:04:09 PM
Is there a better after market trans fluid to replace the stock stuff with.   :idk:  Looking for something that will be smoother and quieter. :huh:
Title: Re: Trans. fluid
Post by: jwvess00 on August 01, 2010, 09:30:38 AM
Hi there!
Red Line and Royal Purple both sell trans fluids (both manual and automatic) but I don't know that it will make anything smoother.
Post by: Critterman on August 02, 2010, 01:19:58 PM
It may just be a placebo effect, but I have royal purple in my trans and rear, and everything seems quieter and smoother.
Post by: Brazen17 on August 02, 2010, 03:26:28 PM
Will the royal purple cause any warranty issues?  Even if it's a placebo effect I'll take it.  It's not a bad shifting trans., just seems a little ruff around the edges if you know what I mean.  I've heard a heavier shift knob helps the feel also.  Anybody here have an after market knob with a little more heft?  If so, how does it compare to stock?
Post by: smartin on August 02, 2010, 03:35:59 PM
I have a new hefty shifter knob that really helps! It feels stronger in my hands and I am able to do more with it!
Post by: Brazen17 on August 02, 2010, 03:37:24 PM
uhhh....no.   :D
Post by: smartin on August 02, 2010, 03:39:14 PM
Just sayin' :idk: :lol:
Post by: rich71 on August 02, 2010, 06:15:50 PM
 i haven't done the RP fluid change as i don't feel like it yet, i will do it at some point ... but......shift at higher rpms like 5k and above.  I have the JPM shifter with the heavier steel knob. I started off with the composite knob, but switched to the steel knob. it definitely makes shifting easier and less clunky. the stock shifter is heavy so it numbs the grind between 1st and 2nd and the inertia of the heavy knob helps "slam" the gears without feeling you are fighting the trans.
PS - - dont forget its a truck transmission
