Author Topic: What are these from in-tank fuel pump  (Read 2988 times)
« on: March 31, 2011, 05:46:00 PM »
I have a spare in-tank fuel pump, I plan to use it in a parallel custom build tank with race gas.
The guy who will build the tank asked me if he can drop some parts from stock fuel pump and I wasn't sure what to tell him because I don't know what are those parts :(
So this is part #1 market with blue border:
Part #2 is smaller and harder to see it in this picture market with red (sorry I couldn't find a better picture), is like a lighter blue as the previous one and looks like a cylinder siphon:
Also not sure if my information is correct and I need a confirmation for connections:
orange - fuel regulator
green - fuel output hose toward high pressure fuel pump
yellow -  looks like pump power source but it has a strange part (see the picture below)
pink - not sure
« Last Edit: March 31, 2011, 05:49:27 PM by Kelu »
Offline spider
Re: What are these from in-tank fuel pump
« Reply #1 on: March 31, 2011, 05:57:48 PM »
yellow-----fuel pressure sensor
pink------fuel sender (float & pump)
Offline Divingsolo (formely Randy@DDM)
    • DDMWorks - Your total Kappa Performance Solution
« Reply #2 on: March 31, 2011, 08:48:48 PM »
the yellow is actually the in-tank MAP used for the EVAP system.
Randy@DDMWorks.com
www.DDMWorks.com
Offline spider
« Reply #3 on: March 31, 2011, 09:39:15 PM »
fuel pressure sensor <----from the manual. Should be <(TAP)>Tank Absolute Pressure sensor ;)
Offline spider
« Reply #4 on: March 31, 2011, 10:03:47 PM »
Ok, its (FTP) Fuel Tank Pressure sensor which if having problems would throw P0451,52,53 or 54
« Reply #5 on: April 01, 2011, 01:45:20 AM »
So I wouldn't need yellow in my case, right?
Offline spider
« Reply #6 on: April 01, 2011, 07:40:35 PM »
I would think not. I'm assuming you are using a vented tank, putting the vent out to the exterior of the car. I doubt the tank needs to be pressurized for the pump to function properly. >>???
« Reply #7 on: April 02, 2011, 08:41:45 AM »
Not sure either  :idk:
I was looking for a parts manual information about in-tank fuel so I could figure out what parts I can remove but couldn't find  :idk:
« Reply #8 on: April 02, 2011, 02:22:16 PM »
Kelu my guess is that they keep the fuel tank slightly pressurized so that they can contain the fuel vapors better then if it was just vented.  The fuel system won't get vapor lock and the vapors aren't leaked to the outside air like in cars of the past.  The sensor in question is needed because if there isn't enough pressurization then fuel may not flow, vapor lock, this also why you get the check fuel cap warning.
If you tee in a new tank and have a valve that shuts off flow from the main tank then the system will just test the main tank, see that it is pressurized properly and not give you any errors.  You should be able to just vent your racing tank and have no problems.
« Reply #9 on: April 02, 2011, 06:34:30 PM »
My thoughts are same as yours SA.
Still not sure if I can give up on the 2 parts from the top and same some space.
