Author Topic: ZZP 2 Bar MAP for LE5  (Read 3730 times)
Offline 2.4solstice06
« on: July 27, 2012, 07:24:03 AM »
So I'm just trying to get everything in order for the turbo install (jinsuko3's and Compression's old set up) and I was just wondering if the 2 bar MAP for the LE5 is something I'm going to need for this and why? I have searched and found several results on the cobalt forum but they are pretty inconclusive. What are the advantages? disadvantages?
Re: ZZP 2 Bar MAP for LE5
« Reply #1 on: July 27, 2012, 08:53:10 AM »
Not sure which one they are using, but if it is the same 2 bar MAP we sell and use in our forced induction 2.4L kits, it allows more accurate fueling and better fueling during transitions.
The only downside is buying it that I can think of and setting it up in the ECM.
Hope that helps,
Dave
____________
Offline idkfa
  • Violent Jain
  • mostly harmless
    • Make
« Reply #2 on: July 29, 2012, 02:26:56 PM »
Isn't it because a 1bar sensor can't accurately measure the pressure above normal atmosphere?  Can a 1bar even provide the correct fuel in FI setups?
« Reply #3 on: July 30, 2012, 07:54:30 AM »
You are correct, since the stock MAP sensor on the 2.4L is a 1 bar sensor, the ECM does not know when you are above atmospheric pressure. I am not sure anymore, but there used to be several kits for the Solstice/Sky that only used the stock 1 bar MAP sensor and they run ok. The 2 bar helps with transitions between vacuum and boost more then full throttle conditions.
