Author Topic: Where To Mount XM Antenna  (Read 4784 times)
Offline IBDRINKEN
  • Donkey Master
« on: January 09, 2014, 04:15:22 PM »
So I have installed an aftermarket radio with Xm and was wondering where the best place to mount the XM antenna. Right now I have it mounted on my windshield which looks very tacky. Any help is much appreciated.
« Last Edit: January 09, 2014, 04:27:37 PM by IBDRINKEN »
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
Re: Where To Mount XM Antenna
« Reply #1 on: January 09, 2014, 04:33:10 PM »
Would the middle of the convertible top be less tacky?
I think the factory location was middle of the aft trunk/bumper area.
Offline IBDRINKEN
  • Donkey Master
« Reply #2 on: January 09, 2014, 04:49:37 PM »
My factory one is on the truck like everyone else. I was trying to get if off the windshield but that might be my other option
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #3 on: January 09, 2014, 05:27:36 PM »
Can you mount it behind the rear bumper cover over the rear bumper structure/bar ?
Offline Jim
« Reply #4 on: January 09, 2014, 05:32:52 PM »
How about on the dash close to the windshield? You should be able to tuck the cable so that it is out of sight and the antenna should work just fine since it will still have a clear view to the sky. On other vehicles that I have mounted XM radios in, I usually installed the antenna on the deck behind the rear seat but we have no rear seat or deck so the dash should work fine. The XM antennas are pretty small so it could actually look like it belongs there.
« Reply #5 on: January 09, 2014, 05:37:54 PM »
When I installed my gps, I installed that antenna on top of the cubby in the waterfall panel behind the seats. You have to get the back panel out to get there but it works awesome, is a satellite signal a satellite signal?
Offline Jim
« Reply #6 on: January 09, 2014, 05:42:20 PM »
Out of sight - out of mind. Great idea!
Offline IBDRINKEN
  • Donkey Master
« Reply #7 on: January 09, 2014, 05:48:49 PM »
I was thinking of installing it under where the visor mounts on the windshield surround. I wonder how the signal will be
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #8 on: January 09, 2014, 09:32:37 PM »
I posted on the solstice forum
« Reply #9 on: January 09, 2014, 09:46:07 PM »
Well I can't take all the credit, the idea was originally this guy's. ^^^^^^^^^*
Full signal with it installed there as well.  :thumbs:
Offline IBDRINKEN
  • Donkey Master
« Reply #10 on: January 09, 2014, 11:05:41 PM »
I saw ur post deep and tried that spot and I had little to no signal so I put in the corner of the dash, you can barely see it
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #11 on: January 10, 2014, 06:38:41 AM »
This is the spot
« Reply #12 on: January 10, 2014, 07:46:46 AM »
Why not just buy an adapter "pigtail" and connect it to the existing XM antenna? When I had Sirius I contemplated removing the OEM XM antenna and mounting the flat, magnetic, disc shaped Sirius antenna in its place, but I never got around to it.
« Reply #13 on: January 10, 2014, 09:51:43 PM »
This is the spot
Dee has sent Joe a picture with this same caption at least a hundred times. He still can't find it.
« Reply #14 on: January 12, 2014, 09:07:16 AM »
:coffee:
Offline pointhunter75
« Reply #15 on: March 09, 2014, 01:05:16 AM »
You can adapt it to use the factory xm antenna on the trunk.
Offline IBDRINKEN
  • Donkey Master
« Reply #16 on: March 09, 2014, 10:24:21 AM »
I just bought this extension to,use the factory antenna and it works fine but you might want to get the 15ft instead of the 10ft.
http://www.amazon.com/gp/product/B004SPZG7A/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
