Author Topic: WTB: Steering Wheel Center Cap (Pontiac)  (Read 1909 times)
Offline JesseB
« on: March 26, 2014, 09:16:51 AM »
hey guys, im looking for the center cap for the steering wheel
Offline JesseB
Re: WTB: Steering Wheel Center Cap (Pontiac)
« Reply #2 on: March 27, 2014, 07:42:31 PM »
Interesting...    :pop:
Offline CaliforniaDreamin
  • "There can Be Only One"
« Reply #3 on: March 27, 2014, 10:27:54 PM »
It would be a lot more interesting if anyone could come up with a supply of the Saturn ones.  :drive:
CaliforniaDreamin' (Big Wave Dave) 07 Redline
JPM CONSOLE AND ARMRESTS,GMPP C.A.I.,SHORTY ANTENNA,
CUSTOM LIGHTED WINDRESTRICTOR,
CUSTOM LIGHTED DOORSILLS,
'09 SPLIT SPOKE OEM WHEELS,CUSTOM CENTERS,POLISHED TURBO COVER,LOWERING SPRINGS,
PAINTED ENGINE COVER, BILLET ENGINE BLING
MGP CALIPER COVERS,OEM SPLASH GUARDS.
(some items awaiting install!)
Offline DragonSolGXP
« Reply #4 on: April 20, 2014, 03:41:42 PM »
Anyone know how these install? The new one I have seems to have long tabs that bend over.... Do you need to remove the airbag?
« Reply #5 on: April 22, 2014, 06:08:22 PM »
I have installed an aftermarket steering wheel center cap.
To remove the factory one I didn't have to remove the airbag, it had some tabs like u said and it was just a matter of pulling it out.
The aftermarket one had a sticky surface, no tabs, so again, no point to remove the airbag.
If you need to bend some tabs I would say you have to remove the airbag, just guessing here.
« Reply #6 on: April 23, 2014, 09:09:34 PM »
Remove the factory airbag and drill out 4 rivets.  then you can get access to the emblem.
