Author Topic: Big 3 Audio Upgrade - Power Cables - Ground - Alternator  (Read 16313 times)
Re: Big 3 Audio Upgrade - Power Cables - Alternator
« Reply #25 on: June 10, 2014, 12:09:29 PM »
Sorry about my smartazzness.  :sorry: :banghead: I'll try to be of more help.
You're mean!!!  ;)
Re: Big 3 Audio Upgrade - Power Cables - Ground - Alternator
« Reply #26 on: June 10, 2014, 01:04:15 PM »
Merged the two topics
Offline darrylba
« Reply #27 on: June 10, 2014, 02:11:33 PM »
Yeah, the ground wires will be a relative easy assignment. Just trying to follow the power wire, it appears it goes to a distribution block on the starter and then to the Alternator. To many obstructions to see where it actually goes. I will have to remove some parts to get a better look this weekend.
« Reply #28 on: June 10, 2014, 04:42:44 PM »
Does this help?
« Last Edit: June 10, 2014, 04:46:08 PM by TomatoSoup »
« Reply #29 on: June 10, 2014, 07:27:42 PM »
Thanks for the pics, TS! I still can't tell which wire is connected to the alternator from the drawings. It looks like #8 in the second picture might be it. Anyway, removing the intake manifold and throttle body shown in the OEM configuration above should give you access to the terminals on the alternator. But don't take my word on that.
« Last Edit: June 11, 2014, 07:26:01 AM by Helios »
Offline darrylba
« Reply #30 on: June 10, 2014, 09:26:12 PM »
Notice in picture #2, that ring terminal from the power cable, looks like its going to some type of distribution block on top of what appears to be a starter. If you then look down to picture #3 then u will see straight lines drawn to that block. Looks like there is a another ring terminal going into another direction to a plug that appear to plug into the alternator.
I tried to post pic show it. But I gave up.  Nice pics Tsoup!
db
« Reply #31 on: June 10, 2014, 09:45:27 PM »
Thanks for the pics, TS! I still can't tell what which wire is connected to the alternator from the drawings. It looks like #8 in the second picture might be it. Anyway, removing the intake manifold and throttle body shown in the OEM configuration above should give you access to the terminals on the alternator. But don't take my word on that.
Good Helios
